TH350 swap problems
Old Aug 11, 2008 | 12:58 AM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
TH350 swap problems
I am finally swapping in my 385 and th350 into my 82 z28 but I have run into a issue with my cross member. The tranny mount stud is about a 1/2 to 3/4 inch to far back to go into the slot. I thought the th200c and the th350's mounting location is the same. Did I do something wrong or what?
Old Aug 11, 2008 | 07:55 AM
gearhead18's Avatar
Re: TH350 swap problems
That is the supposed story that i was told. Sounds like you need the B & M Swap kit. It should come with a relocator for the mount on the crossmember. or at least that's what i did with my swap.
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
