9 bolt questions
Car: 89 Formula
Transmission: TH 700R4
9 bolt questions
Is the 9 bolt a positraction diff or limited slip?
I did a nice burnout the other day but only one tire was smoking
My rear end is the factory BW 9 bolt with 3.27s--it was rebuilt a few years ago--maybe 10K miles on it.
No other issues.
No other issues.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 9 bolt questions
It'll only be a posi if you have a G80 RPO code. I think just about all the 3.27 geared 9 bolts do have posi but not all 9 bolts have posi. The 9 bolt was also offered with 2.77 gears. Not really a performance gear set that needs posi but some probably came with it.
Posi's don't last forever. They do wear out and need to be rebuilt or replaced. Since your diff was supposed to have been rebuilt, was the posi rebuilt as well?
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Only difference is the BW 9 bolt has cone type posi's and 10 bolts use clutches. What exactly was done in the rebuild? the 9 bolt is a pretty hard thing to find parts for, so you must have paid a pretty penny to get it rebuilt, unless you did it yourself.
Car: 89 Formula
(only IROCs got the 2.77)
I will go over the recipets and see what was done
previous owner rebuilt that (along with trans) Car runs great
Car: 87 IROC L98
Some 305 IROC's with a manual transmission had an optional 3.45 9 bolt instead of a 3.08 10 bolt.
Car: 89 Formula
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
i have a 87 formula 350 with the 3.27 limited slip 9 bolt, 4 wheel disk ... but my other 86 TA had 305tpi LB9, with 2.77 9 bolt with limited slip and 4 wheel disk.... hmmmm
and im pretty sure u cant rebuild the stock 9 bolt limited slip... they just replace it completly with a stock limited slip... which is weak as is. hate that they dont make aftermarket parts for the 9 bolt. so if he rebuilt your 9bolt he just made it a new stock 9 bolt which will die behind anything more than 300hp. still its stronger than a stock 10bolt
thought all the 10 bolt gears where... 2.73/3.23/3.42
thought all the 9 bolt gears where... 2.77/3.27
Car: 87 IROC L98
3.70 was available over the counter from GM at one time but never offered in a production car.
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
3.73 are for the GM 10 bolt and are not available for the 9 bolt. I think they did offer the 3.73 in the 10 bolt from the factory but I'm not sure.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
