VSS disconnect?
Old Nov 21, 2000 | 01:27 PM
TK87TA's Avatar
VSS disconnect?
I have an 1987 Trans Am with a 700-R4, if i disconnect the VSS (two wire plug where the speedo cable would go) would that screw up the computer (SES light..etc...)? in PA if you drive under 5000 miles a year, you are exempt from the sniffer test.if i disconnect the speedo, i loose the gauge, but i also loose the odometer, too right?
1987 Trans Am
Black & Gold
Light Mods
[This message has been edited by TK87TA (edited November 21, 2000).]
Old Nov 21, 2000 | 06:29 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
It will stop the odometer, but you will probably have idle and stalling problems, since the ECM uses speed to adjust and reset the IAC valve. Yes, you will have an SES light (code 24).
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Old Nov 21, 2000 | 07:33 PM
TK87TA's Avatar
my car is a 4 bbl car no F.I. there is no IAC.
1987 Trans Am
Black & Gold
Light Mods
Old Nov 21, 2000 | 07:46 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You never stated that. You will just have a code, no speedo, no cruise, and I highly doubt any changes is fuel milage, but you won't have the stalling.
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Old Dec 24, 2006 | 01:46 PM
KnightKap's Avatar
Car: 1987 Black GTA
Axle/Gears: not sure..
GMtech I need your help! I'm having a real problem with my speedo/vss on '87 GTA 5.7 TPI Auto. I've thrown good money after bad on this... no fix! When I start, speedo is dead, 10-15 mins later, check engine comes on, speedo comes on and starts jumping, shortly thereafter, car goes in what I beleive is called 'limp mode' in 3rd gear.. lousy driving this way!.. only accelerates if I floor it!. I can fix this be pulling out 10amp fuse under 'gauges' but then I lose entire cluster and it runs/idles rough but at least no limp mode! what a trade off!.. anyway my question is : seeing as for the first 10-15 mins I get no signal from the vss to speedo (and the cars runs perfect with dead speedo), why not just cut that wire from vss to speedo and problem solved (i can live without speedo).. your thoughts? thank you
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
