Rearend Gears in 88 GTA?
what gears were available in 88 GTA's w/limited-slip. I have access to one if I want it, but I want to know if they came with 2.73's because I did the turn the tire thing and the shaft turned less than 3 times. Seems kinda dumb to put 2.73's in a limited-slip rear!
<A HREF="http://albums.photopoint.com/j/View?u=1229597&a=9072781&p=29492901
Ned" TARGET=_blank>http://albums.photopoint.com/j/View?u=1229597&a=9072781&p=29492901
Ned</A> "Drive Harder"
Stock 305TBI,
Eibach Sportline Springs,
Koni Struts and Shocks,
SSPE lower control arms and Panhard bar,
Hellwig Rear Swaybar and Energy Suspension bushings.Aluminum Driveshaft
Stock 305TBI,
easy way to find out is to pull the cover and find the ratio stamped on the gears. it would look something like this 11:41. just find the ratio and divide and you'll have the ratio.
-=ICON MOTORSPORTS=-
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Is this a 305 GTA? All 350 f-bodies in the late 80's got 9-bolts, either 2.77 or 3.27. If its a 10-bolt in an 88 GTA, then it has to be a 2.73 rear end.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 2002 SOM z28
Do all late- 80s 3.27 9-bolts rears have posi differentials too?
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
Are you sure dude? Count the number of bolts in your differential. You should have the 9-bolt 3.27 rear end in your 88 GTA.
Re: Rearend Gears in 88 GTA?
D00d...
He posted that over 25 years ago.
You can try a private message or an e-mail butt the odds aren't good.
