Clutch T.O. Bearing Problems
Old Nov 16, 2000 | 07:40 PM
SniperStrike's Avatar
I own a 92 Camaro, 305 cid, 5 spd. Recently, the "Chevy Guys" replaced the clutch, pressure plate, pilot bearing, and throw-out bearing. Afterwards, (24 hrs)a high pitched squeel would come from underneath the car. Had the throw-out bearing replaced. Worked for about 3 days, squeel came back. Note: squeel stops if you place light pressure on the clutch pedal. Chevy guys think it might be a worn clutch fork, but they seem to balk at any concrete solution. Any ideas, suggestions would be very helpful as the C.Gs want to charge me again to pull the tranny to replace a fork that they don't seem too sure will solve the problem.
Old Nov 17, 2000 | 02:30 AM
ONEFINE8T9's Avatar
i believe it could possibly be the clutch fork. I mean if its bent the T/O will really gently ride against the pressure plate making a squeek noise until minium pressure is applied
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
system: 2 10" MTX thunder 2000 in a Professionally done custom bandpass box.
Blaupunkt CD player
Blaupunkt 4x6 and 6x9
600 watt rockford fosgate 4.6 amp
thinking about a flowmaster
Old Nov 22, 2000 | 05:13 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
It might be your front bearing on your tranny. Mine is wearing out and is making a sound when I am in neutral and the clutch is not engaged, as soon as I press the clutch and put it in a gear the sound goes away. My mechanic and a tranny shop said it was the front bearing on the tranny making the sound.
Can't hurt to have it checked. Take it to a tranny shop and let them hear it.
Zepher
'86 Pontiac Trans Am WS6, 5 Speed:
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Recaro Seats,
Alpine CD+Changer,Rockford & Soundstream Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
WS6 Trans Am
dyeager535
Aug 28, 2015 08:10 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
19irocz85
Aug 26, 2015 07:54 PM
rsrmoore
Aug 7, 2015 08:44 PM
