Has anyone removed their torque arm?
Old Nov 25, 2000 | 07:36 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I mean removed it for good. What did you have to do to make up for it? Any pics?
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm
Old Nov 25, 2000 | 08:39 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The Torque Arm is a very vital piece of equipment. It prevents the differential from rolling foward or bacwards under the various torque loads placed on the drivetrain. Most RWD vehicles use a rigid mount to a leaf spring (trucks) or upper and lower control arms (caprice, Impalla, etc...) The F-body I think lacks the structural support for upper control arms, so they just mounsted a long bar to the tranny tailshaft.
If you wanted to delete it, you would have to find someway to attach some sort of brace from the diff, to the body, and yet be flexible to allow suspension travel, but be rigid to prevent diff roll (there is a term for that, I just don't remember). Why are you trying to delete it?
Old Nov 25, 2000 | 12:10 PM
ede's Avatar
ede
if can be removed and left off. you'd have to add ladder bars and a cross brace for the forward mounting point. why would you want to remove it?
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 25, 2000 | 01:28 PM
Engine: 4.0L
I'm keeping mine. My friend is swapping a 2.8 for a 5.0 and can't find a V-8 Auto trans so he's getting a T350 instead. There's no place to mount the torque arm so he asked how to delete it.
I understand it's vital but I have seen pics of cars without one, I just can't remember what they did. I'm getting old.
We'll probally get the B&M kit for 700R4 to T350 from Summit.
86 Camaro Sport
[This message has been edited by John Millican (edited November 25, 2000).]
Old Nov 25, 2000 | 01:46 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Oh yeah, I forgot about your friends dilemma. I still think he should get a V8 700. Hell, if he can't afford one, have him buy one thats burnt up, I throw some clutches in it for him. I won't charge to much. He will probably spend less money, have less headache, and retain overdrive. Has he called cash and carry?
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Nov 25, 2000 | 04:34 PM
ONEFINE8T9's Avatar
i thought the 2.8/3.1 had the same tranny (700r4) as the v8s. Please correct me if im wrong-Mike
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
system: 2 10" MTX thunder 2000 in a Professionally done custom bandpass box.
Blaupunkt CD player
Blaupunkt 4x6 and 6x9
600 watt rockford fosgate 4.6 amp
http://members.aol.com/j007golden/Mikey89.html
Old Nov 25, 2000 | 04:42 PM
ede's Avatar
ede
tell your "friend" he needs b&m pn 30299. all his problems will be gone for about 75 dollars.
1st & 3rd
Old Nov 25, 2000 | 04:44 PM
Engine: 4.0L
Your wrong
The 2.8 and 3.1 were 60° engines. The 5.0 and 5.7 are 90° engines. Totally differant bellhousings.
I believe the 4.3 is a 90° engine so it should be a match.
Old Nov 25, 2000 | 04:47 PM
Engine: 4.0L
I found that part number yesterday and it's on order. Have you seen it? Does it come with a new crossmember?
I do remember seeing someone delete their torque arm on this board. Said they did it for the weight...
86 Camaro Sport
Old Nov 25, 2000 | 07:48 PM
ede's Avatar
ede
have one sitting on the floor here all it is is a bracket that bolts to the trans and the torqe arm mount bolts to it.
1st & 3rd
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Ducati900ss
Sep 2, 2015 09:05 AM
zayne0
Aug 24, 2015 07:22 PM
