Whitch shiftkit should i get?
Old Aug 18, 2008 | 11:16 AM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
i found a few shiftkits im lookin at wich one would be best.
http://store.summitracing.com/partdetail.asp?autofilter=1∂=TCI%2D376000&N=700+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1∂=TRG%2D700&N=700+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1∂=BMM%2D70239&N=700+115&autoview=sku
i also know theres one someplace modifies but i forget if anyone knows wich one im talkin about gimme the link please. i think it was dana or something?? im not sure.
thanks nate
Old Aug 18, 2008 | 11:46 AM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
Re: Whitch shiftkit should i get?
i used the b&m shift kit though jegs on mine and it works great heres the part number if your intrested 130-7023
I also put in a corvette servo and a 2800 stall i can tell you it shifts amazing i can squeal the tires in 1st and 2nd then put it in od for cruising
Old Aug 18, 2008 | 12:14 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Yea thats what i want i want my 305 to chirp 2nd lol i want to be able to leave marks without holdin the brake lol/
Old Aug 18, 2008 | 12:57 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
www.700r4l60e.com =
Bill
Old Aug 18, 2008 | 03:18 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
theress a lot there but i couldnt find the one i saw along time ago. wich one would be the best one for me its just a street car might see the strip once but rreally just a street car. thanks nate
Old Aug 18, 2008 | 03:40 PM
Burnout91's Avatar
Engine: Modded L98
If you call or email Dana at ProBuilt, I'm sure he will dial in just what you need. I've had shiftkits from B&M and Superior in my car. Dana's modified TransGo shift kit is by far the best, smooth part throttle shifts and quick, clean and FIRM shifts at heavy or full throttle.
Bill
Old Aug 18, 2008 | 06:56 PM
Jammin'Trey's Avatar
trans go with corvette servo.
Old Aug 18, 2008 | 07:11 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
is it hard to instal a shift kit??
Old Aug 18, 2008 | 07:17 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
https://www.700r4l60e.com/store/prod...&cat=65&page=1
That is the shift kit to get
Old Aug 19, 2008 | 12:29 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Originally Posted by krisb410
Yep. That's the one I have. Love it.
Old Aug 19, 2008 | 07:23 AM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
sweet then thats the one ima get since everyone likes it best thanks. Do you guys think its hard to instal a shift kit???
Old Aug 19, 2008 | 04:20 PM
Car: 1989 GTA
I wouldn't do it myself. But I've never taken a transmission apart before. I think I payed 3 hours labour to get a transmission shop to install it. There are A LOT of custom instructions with the Pro Built shift kits.
Old Aug 19, 2008 | 07:44 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
do you guys think my car will chirp second with a shift kit? It almost chirped once after i changed the plugs and cap an rotor. Also should i get a diff tourqe cconverter with that setup or is the stock one ok idk how much power ima be making after i get the headers and other miscilenis items on. Another stupid question what exactly dose a tourqe converter do??
Old Aug 19, 2008 | 07:51 PM
krisb410's Avatar
http://auto.howstuffworks.com/torque-converter.htm
Old Sep 1, 2008 | 08:40 AM
3rdgenBrad's Avatar
Car: 1992Firebird white
Engine: 305 TBI w/ holley open element
Transmission: automatic
Axle/Gears: i think 2.73 tell me if im rong
Has any one ever done a b&m shiftkit in a 305 tbi setup? is it even worth it. i used to own a 2001 neon w/ a glasspack and a full length intake and short shift and i used to beat my buddys camaro 6cy. i think my my fire bird is a bit quiker but i also think a shift kit is an inexpensive thing to do. i also plan on a B&M mega shifter. pros cons ??????????????
Old Sep 1, 2008 | 03:53 PM
krisb410's Avatar
A majority of peeps here will pass on the B&M shift kit, and tell you to go with the custom Transgo shift kit from Dana and Probuilt Automatics. It's just a much better kit.
Old Sep 1, 2008 | 04:33 PM
3rdgenBrad's Avatar
thanks for the quik response
does it install any differently than the b&m kit, does it truley need "customization" or is it like the other. i had planed on driveing to an autoparts store locally and buying the b&m kit cuz it is easier for me than ordering online. i guess my main concern is will it hurt the stock tranny or drive train without other mods, i also have the same question about the mega shifter. thanks again.
Old Sep 1, 2008 | 10:50 PM
krisb410's Avatar
The Probuilt/Transgo kit is just perfect, the kit is custom, not "customization" needed on the tranny. It is rumored that the B&M kit can and will harm your tranny, whereas the Transgo kit is actually beneficial for your tranny
How is it easier to drive to a store to buy it, when ordering online they deliver it right to you??????
If your car is a daily driver, I have heard that the mega shifter is a bad idea. Something about it being a bad shifter for a daily driver, but great if your car is mainly for the track.
I have a B&M kit that I bought but never installed, it's yours for $25 if you want it. I bought it, then did the research, and ended up buying the Probuilt/Transgo kit. I extremely recommend get the same kit as well.
Old Sep 1, 2008 | 11:18 PM
TurbomanKnight's Avatar
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Which part do you need to allow the car to go WOT in OD?
Old Sep 1, 2008 | 11:26 PM
krisb410's Avatar
Damn, you too lazy to do a search??? Here you go https://www.thirdgen.org/forums/tran...own-valve.html
Old Sep 2, 2008 | 12:28 AM
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
I would've searched but I didnt know what it was called. Thanks for the link!
Old Sep 2, 2008 | 07:01 PM
3rdgenBrad's Avatar
thanks for the info! it is a daily diver but, iv allways driven standerd and i wouldnt mind the manual shifts. i always wanted one before but never had an automatic before now. and i think it would be cool. i might not go with a b&m shift kit though. also i dont have a credit cad thats why its easyer to buy locally. i know alot of stuff is cheaper online but is hard to get some one to buy stuff online with me. im definitly going to do it to get my car audio though.
Old Sep 2, 2008 | 07:48 PM
Pro Built Automatics's Avatar
I take personal checks, or money orders. Dana
85Special
Sep 3, 2015 04:21 PM
88greyiroc
Dec 13, 2001 11:02 AM
sunbound
Sep 23, 2001 05:06 PM
RSpeed
Aftermarket Product Review
Dec 1, 2000 07:30 AM
