B&M kickdown valve
Old Jul 20, 2008 | 10:25 PM
Jammin'Trey's Avatar
B&M kickdown valve
Anyone have one? How do you like it. I want to be able to get into OD at full throttle. This will probably help my E.T. alot in the 1/8th. Going down to M.A.M. this weekend and dont want my 305 to get its *** handled by stock civics. lol
Im putting in a 3.73 gov loc and a shift kit by B&M aswell. Wish I could afford the LS1 driveshaft right now too.
Got a set of new 275/60 15s Im gonna throw on too...
Old Jul 20, 2008 | 11:35 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: B&M kickdown valve
I did a search, and look what I found.
https://www.thirdgen.org/forums/tran...hlight=valve+b
and there were a few more to be found.
Old Jul 20, 2008 | 11:49 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
You're shifting into overdrive in the 1/8 mile?
The B&M will still allow the transmission to shift from 4-3. It's just that it takes more gas pedal for it to occur. So instead of downshifting into 3rd and coming into 3rd at the red line, it will be higher (way into the red).
You want this one. http://www.transmissionpartsusa.com/...-7796694mk.htm
The 77966-94MK has the part throttle holes solid (no holes). This allows the WOT 3-4 shift to occur.
Old Jul 21, 2008 | 08:27 AM
Is that going to effect any of my other shifts? What i mean is will it go OD at notmal 1/4 throttle or so?
Old Jul 21, 2008 | 10:17 AM
Car: 1989 GTA
Makes no difference shifting 1-2-3-4 (with the exception that you can make a WOT 3-4)
As for downshifting, it means you need more gas pedal to make the 4-3 shift during normal driving. And anything above 90 mph or so, it will stay in 4th gear even with the pedal to the floor (assuming you were already cruising in 4th).....I like this feature. Because when you're going that fast, you don't really need a downshift to 3rd. You'd be running out of room in 3rd gear fast enough anyways. (You could manually pull it back into 3rd if you really wanted to.)
It's just the part throttle 4-3 shift that's eliminated with the valve. The annoying one that gives you the 4-3-4-3-4-3 constant back and forth shifting. If you slow the car down enough, it will still make the regular downshift to 3rd on it's own.
An example would be going 45 mph in O/D and then merging on to a highway. With the valve, it would take about 70% throttle to get a downshift. Without the valve, it would take about 30% throttle to get the downshift. The faster you go, the more gas pedal you need to make the 4-3 downshift.
The valve makes the car shift like the C4 Corvettes did.
Old Jul 21, 2008 | 08:09 PM
Pro Built Automatics's Avatar
You can install two Allen plugs in the 4-3 downshift passages in your existing throttle valve bushing to accomplish the same thing. You do not have to remove the valve body for this. I can fax the instructions on how to do this. The cost of two Allen screws, about 40 cents.
Old Jul 21, 2008 | 09:30 PM
could you post them up? I am very interested. I am taking the valve body down here soon to install a shift kit so that doesnt really matter.
Never driven a c4 corvette........
Old Jul 21, 2008 | 09:45 PM
krisb410's Avatar
Hey Dana,
This is the directions you sent me when I bought your modified Trasngo kit. So I need to plug both the holes, even though only 1 of the holes is identified? What size Allen screws do I need to buy? Why is there A, X, and B identifiers?
Old Jul 22, 2008 | 12:19 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
i have the valve and it works great, does wat it says it does. i can cruize at higher speeds like 120mph lol. if u step down on the go pedal more than 60-70 % then it will downshift from 4-3 but if u stay below that 60-70% it will stay in 4th resulting in higher cruizing speeds. it was wayy better than sstock but im gona do the WOT4th gear valve mod stated above... since i want more lol. so please post the instructions and parts needed.. thanks dana
Old Jul 23, 2008 | 01:34 AM
The Allen plug measures .160" - .162" in diameter. It is "self tapping". I modified the instructions from Steve Younger to prevent the 4-3 downshift at higher speeds. So X and B are not involved anymore. Dana
Old Jul 26, 2008 | 09:02 PM
Car: 87 TA clone
so i have to plug the PT hole wit the .160-.162" self tapping allen plug? and thats it?
where can we get these allen plugs from?
Old Jul 26, 2008 | 09:23 PM
krisb410's Avatar
Look's like you have to plug both of those holes.
Old Jul 27, 2008 | 10:47 AM
I get them at a hardware store. There will be two holes "A" to plug.
Old Jul 27, 2008 | 08:52 PM
Car: 87 TA clone
so i have to plug 2 holes. the "PT" and the hole horizontal to it in the pic?
can i do this to my B&M kickdown valve?
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
