in 3rd gear my car is running at 3100 rpm what gear ratio do i have?
Old Nov 27, 2000 | 02:12 AM
hookin88formula's Avatar
this is something i need to know so i can put different gears in something like 3.73.. i had those in a different car and loved them for both street and strip.
1988 firebird ws6 formula350tpi msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter, march underdrive pullies, tpis airfoil cvr high torque starter (love it)
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system
Old Nov 27, 2000 | 09:11 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
At what speed and type of transmission?
If it is at 60 mph and an automatic, it sounds like 3.27s (assuming you have the 9 bolt).
Old Nov 27, 2000 | 12:04 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, you left out a few specs. but heres what i think.
700R4 third gear = 1to1
Tires dia. = 26" (guess)
Eng. rpm = 3100
Gear Ratio = 3.73
MPH = 64
-Auggie-
Old Nov 27, 2000 | 02:15 PM
Car: Death Mobile
Engine: 666 c.i.
At 60 MPH, I am doing about 3,000 rpm with my 4L60, 255/50/16s (25.5" tall) and 3.23s. But that is using the tach which has is not exactly accurate.
With my Diacom, the engine rpm is 1,850 @ 60 mph in 4th. With 3.73s it calculates to approximately 2,125-2,150 rpm in 4th @ 60 mph.
Old Nov 27, 2000 | 02:19 PM
sorry yes it is a 700r4 10 bolt rear end,
when i got the car it had yellow writing on it that said 84 i am assuming this is a junk yard rear end.. it also has the tag to put the special lubricant in it.. and as i said i was in 3rd gear and set the cruise at 70 mph and the take read 3100 rpm.. it just dont seem like i have 3.73 ratio because 1st drops so quick when u put it in gear.. anyways any more ideas since i added what i left out???
Old Nov 27, 2000 | 06:29 PM
Car: Death Mobile
Engine: 666 c.i.
3.23s
Old Nov 27, 2000 | 06:43 PM
ok thanks glen so 3.73 seem like a good gear? so i will have to go with a the 3.73 gear and get the one that the carrier is 3.08 and higher right?
Old Nov 27, 2000 | 06:46 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You want 3.23 and higher. 3.08 is the lower gear.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 27, 2000 | 07:54 PM
Car: Death Mobile
Engine: 666 c.i.
Just to clarify, are you asking which set of gears to get based on your carrier? If so, then yes, you need a 3 series.
specialized
Jun 18, 2022 09:26 AM
AkDrifted
Aug 17, 2015 07:45 PM
dhonda200
Aug 11, 2015 11:50 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
killer777
Aug 8, 2015 02:47 PM
