my rear is leaking out the front how hard is the seal to replace??
Old Nov 26, 2000 | 04:52 PM
superiroc's Avatar
I changed my oil and noticed my rear is leaking bad out the front of my 10 bolt. I assume i just need to replace a seal. I don't know much about the rearend, can i put the seal in without pulling anything out of the rear? I had redline oil in there when i had my richmond gears installed do you think i could of damaged my rear i don't know how much oil is still in there. So far no noises i have been driving my other car.
Old Nov 26, 2000 | 05:26 PM
Blade's Avatar
It's so simple a monkey could do it... All you do is take off all the bolts (10 :P). Then put a container right underneath the differential for the liquid to drain in. Then carefully pry off the bottom of the cover and let most of the fuid drain, then take it completely off. That's it! Scrape off the old gasket, throw on the new one, pour new gear oil in trough the top of the differential after removing the plug, and you're done!
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.org/Members/Chev...dmondIndre.htm
Old Nov 26, 2000 | 05:36 PM
superiroc's Avatar
the rear is leaking from the front of the diff on to the driveshaft sorry i didn't make that clear.
Old Nov 26, 2000 | 05:56 PM
Blade's Avatar
Oh that's a whole 'nother story. Well you'll have to drain the fluid anyway. But I believe you have to take it apart so you can pull the yoke out and replace the seal. I think.. I dont know for sure. Maybe someone else will answer this for u.
Old Nov 26, 2000 | 06:03 PM
superiroc's Avatar
i havn't looked yet but i think i just have to pull off the drive shaft and drain oil and then i think i should be able to pull the seal out and replace it without taking the diff apart or anything else.
Old Nov 26, 2000 | 06:39 PM
82camaro's Avatar
Car: 82 camaro SC
Pull the driveshaft.
Remove big nut in the center of the where the driveshaft connected to the rear end and remove the yoke from the rear-end.
Pry the seal out.
Put the new seal in.
lube the seal with some diff. oil
Reinstall just like it came apart and torque down the nut until all the slack is gone from the pinion bearing.
reinstall the driveshaft and you should be ready to go.
P.S. change the fluid, it probably hasn't been changed in a while anyway.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Nov 26, 2000 | 06:48 PM
superiroc's Avatar
thanks i will do that tommorow.
Old Nov 28, 2000 | 09:19 AM
badbird88's Avatar
you need to put a new crush sleeve in or if you use the old crush sleeve you will need to remember exacley how much torque it took to take the pinion nut off so when you re-install the nut you can torque it back down to what it was before...I personally recommend the new crush sleeve and then torquing the pinion nut back down to what the specs call for...it's a lot to!
Also, don't scratch the yoke up when you have it out. If you scratch or nick it you can cause the oil to leak around the seal. My 2000 GMC sierra had a oil leak the first 300 miles at the rear seal and they replaced the seal w/o replacing the crush sleeve and without checking the yoke for scratches...it was back in there a few weeks later with oil still spraying all over the under side of my truck. The replaced the yoke and crush sleeve and I had no more problems.
bottom line, it's pretty simple but you need to take extra care in getting the pinion nut torqued down properly and will probably require locking the brakes and someone holding the tires at the same time while you torque the nut down.
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
Old Nov 28, 2000 | 09:27 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You don't have to replace the crush sleeve under most circumstances. Normally, from the factory, or when people install new ones, the pinion bearing preload is set to the minimum spec, wich leaves the crush sleeve only slightly crushed. There usually is plenty more to go.
The secret to doing a pinion seal, is to tighten the pinion nut just a tad more than when it was taken off. You can always increase the preload a little, but you can't decrease it. GM says for quick service, mark the nut in relation to the pinion (threads). Then when you are all done, re-install the pinion nut and tighten all the way down untill the lines line back up, and tighten the nut 1/16" further. That will add approximatly 5"lbs of preload. Like I said, you can always go a little higher, but NEVER lower than where it was, or bearing failure is inevitable. And NEVER use an impact to run the pinion nut down.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Exxon Limited
Aug 9, 2015 08:13 PM
