Will stock 700R4 with B&M shift kit hold 500 horse?
I am running the performer RPM complete setup with cam, intake, carb, (cept my heads are camel hump 462 with 2.02 valves and 3 angle valve job, ported and polished) I will be running a 100 shot of nos also on occasion, will the transmission hold this?
Bright red 87 GTA with 350 tuneport. Basic mods such as K&N filter, Flowmasters, Wells MAF, TPIS air foil, Accel 8.8mm plug wires with , Accel distributor cap and rotary buttons.Gutted cat. B&M Shift kit, 100HP shot Nitrous, soon to change over to carburator.
No way in hell. Pro Build Autos says that after about 400 you're treading on thin ice. Of course if you drive around like a grandma and never use those 500 horses then ok.........its all in the way you drive.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI,700R4, Trick Flow Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat,
Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Torque Converter
bsa
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
In stock form, the tranny isnt very strong. But neither is the rear end and i bet that would go first.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
-Justin-
dhonda200
Aug 11, 2015 11:50 PM
