700r4 to 200-4r swaps and convertor opnions needed!
Old Nov 30, 2000 | 12:51 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Ok, well, in the play book it looks as though i will be putting together either a supercharged or turbocharged 355 into my firebird, besides the obvious, i will need to re build the tranny and get a new convertor.
The car will run NA for some time before the turbo or sc is installed, prob about a year. My question is, the 200-4r's have better ratios then the 700's. they were put behind the 3.8 turbos. They seem to hold up fine to about 450 hp stockish and even more built. i plan on putting some money into building them, such as better clutchs and better bands, etc.
Now, i know they make conversion kits, who makes them and how did they work out? anyone actually do this swap? did you find it worthwhile?
also, i would liek to up the stall convertor also... cuz it wil lbe a street car for sometime, i would prefer to get a lock up type convertor to at least HELP some gas mileage. was thinking somewhere around a 2400-3000rpm stall, what brand should i go with? i def don't got the bucks for a vigilante sooooo
make all suggestions ya want!
Steve
86 Firebird, LG4, t-tops, 2.73 open rear, SLP 3 inch cat back exhaust, catco cat.
Gonna be sellin the 86 in the spring to hopefully get an 88-92 formula 350, and supercharge it!! (amoung some other sweet mods)
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.8 on the motor, 12.89 on NOS and slicks! Hit by what else!?!? a FORD EXPLORER!!!!!!
Old Nov 30, 2000 | 05:00 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
never heard of anyone wanting a 200R-4 before! Go with the 700 for a sweet first gear, you may find the 1-2 a bit of a wide ratio but a convertor will help that a bit. 700s are stronger than 200s and there are generally more performance parts available for the 700 for this reason. I believe that the 200 has ratios much like a th350 except for the overdrive gear obviusly
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Nov 30, 2000 | 05:34 PM
fb305svs's Avatar
well, i would really like that first gear that the 200 has though... it would help me launch better i think, although i will be runnin only 342's in it sooooo
Steve
Old Dec 1, 2000 | 03:21 PM
Pro Built Automatics's Avatar
The magazines preach that the 700R4 is Better than the 2004R, NOT TRUE! There are many more 2004R's running in the nines than 7004R's. The lower first gear has no advantage once the car is running better than mid 14's. In comparision tests with a mid 12 second car using the identical torque (same) converter, we ran 7 runs on the 700R4, switched the trans to the 2004R, again 7 runs. Results, the 2004R was a tenth quicker & one mile per hour faster on average. Before the tests we thought the 700R4 would be quicker & the 2004R faster, but the 2004R proved to be better in both cases. I build many of each and have found the 2004R to be more reliable. The gear ratios are as follows, 2004R 2.74-1.57-1.00-.67. The 700R4 3.06-1.63-1.00-.70. The 2004R has three sets of planetary gears, the 700R4 only has two. I would not change to a 2004R if you already have a 700 in the car now. But if you have a choice the 2004R is the better way to go.
Glad Too Help!!!
Old Dec 1, 2000 | 03:28 PM
fb305svs's Avatar
Probuilt, i wouldnt mind the switch, i think i might have a core for a 200 4r, what would it take to get one of you guys to build this tranny up for me? like compariable to a level ten stage two 700 r4?
Steve
camaro11j
Sep 19, 2018 08:49 AM
IROCZ1989
Jan 24, 2016 03:55 PM
TreDeClaw
Aug 14, 2015 06:58 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
