too late for shift kit??
Old Nov 18, 2000 | 08:39 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
my 700r4 was rebuilt 3 years ago,it was a great transmission,it still is a great transmission...........just a little more broken in . I saw a B&M shift kit today,it looks easy to install would the heavy duty version shorten my trans. life under normal driving conditions?? can I restore some performance by adjusting the TV cable,clutch bands? would I even benifit from a shift kit with a sloppy 700r4?
Old Nov 19, 2000 | 07:47 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
your transmission will actually last longer with a shift kit.if you are going to use the "B&M" kit. i have a suggestion. i found that once i had installed mine that the 1-2 & 2-3 shift was actually way too firm.very hard might be a better way to describe it. it was so hard that my wife would no loner ride in my car becuse it would hurt her back from the violent shifts.and after awhile it was even getting on my nerves.
so here is my suggestion. when you install the 1-2 & 2-3 accumulator piston spacers.only install the lomg one.not"both" of them. this is what i did. it was certainly a pain in the *^& going back into the transmission to remove the small spacers from both accumulators,but it was worth it. thanx,ANDYZ28
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter. 9bolt 3.27 w/1LE rear brakes 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc
Old Nov 19, 2000 | 05:29 PM
MrJ's Avatar
MrJ
Avoid the B&M shiftkit, it is trash and will kill your tranny eventually. EVERY tranny that I know of that at one time had a B&M kit, **** the bed sometime down the road. If I were you, I'd go with a TransGo shiftkit, I have one and it's very, very good.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
supposed 'peanut cammed' car (yeah, right)
Built on Wednesday
Old Nov 21, 2000 | 12:04 PM
FastBroker's Avatar
The street/strip version shifts very hard but the Heavy Duty is not so bad. Yo upick which one you want and do the only the mods for your choice.
The B&M shift kits are fine. If they do break early it's only because the shift so friggin' hard that they get abused if not filter/fluid/temperature watched... I recommend the B&M TransPak, though. A little more thorough and worth the extra $25 or so over the ShiftImproverKit...
Old Nov 22, 2000 | 09:46 AM
82camaro's Avatar
Car: 82 camaro SC
.5 tv boost valve and a vette servo. You won't need the shift kit.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Nov 23, 2000 | 12:38 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Check out http://www.superior-transmission.com...correction.htm I have it and I'm very happy with it.
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Dec 1, 2000 | 05:21 PM
Pro Built Automatics's Avatar
Put in the Trans Go Performance along with the .500 main boost valve, .296 intermediate/reverse boost valve, & Corvette servo. You cannot do better than this.
Glad Too Help!!!
Old Dec 4, 2000 | 01:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Definately reset the TV cable; mine seems to slide out every few months. In fact some people forget it after their shift kit, and wonder why the trans doesn't shift as hard anymore. They reset the TV cable, and "wow!"
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
PestilenceIV
Sep 11, 2016 12:53 AM
TheTraut88
Sep 7, 2015 05:22 PM
dimented24x7
Sep 6, 2015 03:51 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
