Bad clutch chatter and neutral engine vibration?
Old Aug 23, 2008 | 11:12 PM
SDalt404's Avatar
Car: 1988 GTA
Transmission: 5 Speed
I just recently had a clutch job done and it has been a nightmare.
First off they give it back to me and the car wont even go into gear. The next day I take it back to them and tell them to check the throw out bearing and sure enough they installed it wrong.
I go to pick the car up again and it goes into gear now but there is HORRIBLE clutch chatter, that shakes the whole car, and a very bad vibration that when I rev in neutral shakes the car pretty bad.
What do you think would cause this? A bad flywheel machining?
Old Aug 24, 2008 | 07:10 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Re: Bad clutch chatter and neutral engine vibration?
I have run into some flywheels that you cant machine. If you do it will throught the balance off and you will have a vibration. For the chatter, what kind of clutch did you have installed? A bad surface on the flywheel or a break-in period might be needed for the chatter to go away.
Old Aug 24, 2008 | 10:43 AM
SDalt404's Avatar
Car: 1988 GTA
I had a ZOOM clutch installed. I think it was $229 from summit.
Old Aug 24, 2008 | 11:10 AM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
I'd have to say if they did the throwout bearing wrong, they either didn't resurface the flywheel or they resurfaced it badly. IMHO.
Old Aug 24, 2008 | 01:31 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Sounds like the dual friction clutch like I have. Mine never chattered after I installed it so Id lean towards something wrong with the flywheel or a bad install.
Jae992
Aug 27, 2015 09:07 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
novaderrik
Aug 10, 2015 12:44 PM
rsrmoore
Aug 7, 2015 08:44 PM
