newbie tranny question....
Old Dec 4, 2000 | 11:47 AM
z28kid93's Avatar
ask me about a 4th gen and i could tell you anything, a 3rd gen, well that's a different story. hehehe. anyways, i was going to get a third gen and do a carb engine in it. i will be ripping out the computer. will there be a problem with the 700R by doing this? will i need a seperate lock-up switch? Also, will all this need to be done as well if i swapped to a TH350? thanks for any advice.
Chris
Old Dec 4, 2000 | 01:26 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You've got it pegged; you'll need to do something for the TCC lockup. http://www.bmracing.com sells a few kits that you can buy through http://www.summitracing.com that take care of this exact swap. Also check out http://www.thegrid.net/thedrivetrainpage/700inst.htm
I don't think this needs to be done for the TH-350, but you will have to rig up the kickdown cable to the carb. Of course you gotta rig the same thing for the TH-700R4, anyway.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 4, 2000 | 07:37 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
OK, here ya go:
1994 Trans Am, LT1 engine, 4L60 Transmission. 50,000 miles, new plugs and wires. Detonates on cyl. #7 under hard acceleration. #7 is the only cylinder that does it, this is verified by removing the #7 plug wire and snapping the throttle.
The engine was de-carbonized, and still does it.
#7 is recieving as much fuel as the other cylinders, and there is no vacuum leaks.
What is causing it and why?
Hey, you said anything.
As for your question, TomP did a pretty good job already.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Dec 5, 2000 | 03:16 PM
FastBroker's Avatar
My Gueses:
The plug has a small burr or metal piece on it that is pre-igniting the mixture prematurely.
Or, that ONE SPARK PLUG is of too hot a range for that engine (guy put one wrong plug in on a tune-up?)
A/Freeze or oil sucking in causeing Pre-ignition (bad head gasket?)
Cap terminals indexed incorrectly for that cylinder and/or some funky slop in distributor and/or timing chain?
Old Dec 5, 2000 | 07:36 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The answer is fairly simple, and is kinda like a "cure all" for these cars. Kinda like letting out some blood will cure you from what ails you.
I was waiting on a reply from z28kid, but I don't want to dog anybody out. I learn new stuff everyday, so I never say I know it all.
Anyway, its the distributer cap on the opti-spark. If you know how they are built, there are "tracks" molded into to cap so that 2,4,6 & 8 are on one side, and 1,3,5 & 7 are on the other side, yet still maintain its firing order as the rotor turns, its real funky. Anyway, over time, they burn out and start to crossfire, so whatever cylinder comes before #7 is firing, but grounding out through the #7 plug. I know this is WAYYYY of topic, so I will shut up now.
Old Dec 6, 2000 | 10:21 PM
z28kid93's Avatar
sorry for the delayed respone. been away for the past 5 days. anyways, i don't know everything!! i know enough to get by solving most major issues. anyways, i would have said something simple like it's possibly the wire being being crossed up or it being bad out of the package(i had that happen) GMTech, you are God!!
Chris
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
rubblerubble
Mar 13, 2016 06:57 PM
bjpotter
Oct 4, 2015 07:48 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
