Dana 44 for 3rd gen F-body?
Ok recently I made a post about the 9 bolt. Well I just got it in and it wasn't the gear ratio I wanted. Only 2.77. Sux don't it? Leaving me with no new rear end. Well after I purchased it I found out that there was a Dana 44 made for the 3rd Gen F-Bodys and they are supposed to be the strongest made. What firebird's and camaro's where these available in? So I might be able to find one. Also what gear ratio's were available in the f-body's? If they have a bad ratio's only like 2.73 will it be easy and relitivly inexpensive to put in a new ratio? Did they come with posi's and drum, disc or both brakes? And Last and very unlikly does anyone know where I can find one? Anyone seen one in their junk yard or local paper or just may happen to have one or has a friend who is willing to part with it? I know thats a long shot but I gotta try. Thanks...... Erik.
Car: 1991 Camaro Z28
I'm pretty sure they only came in the 1992 Pontiac Firehawk. And there are only about 25-30 of those in existence right now I think. Good luck with your search.
1991 Z28 - 350 TPI, T56, McLeod street clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, no cats, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Steve Spohn adjustable torque arm and T56 crossmember
Yeah thats what I was afraid of. BUT I have just found out that they were also put into the 91 firehark (prototype to the 92)Only 6 made. But also the were in the 89 turbo TA A couple hundred made. If anyone else knows what they were put into, let me know. I found out one gear ratio the came with 3.54. Are there any others? Also if you can help with my other questions Or can help me find one I'd really apricate it.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The Dana 44 was a dealer replacement item available from GMPP. Unfortunately it's long since been discontinued. Mine came with posi and discs. Your best chance is probably to just try the junkyard and hope you get lucky.
There was a discussion on this on another thread, and I believe the general agreement was that the Dana 44 actually didn't come on the TTA, or in fact any other factory thirdgen.
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 383 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler.
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes.
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
Hey thanks for the information. Sucks they were discontinued. However I did a little research on this and accoring to SLP engineering, the guys who designed the Firehawk, the 91 and 92 Firehawk's came factory with the Dana 44. I'm pretty sure about that. Also on a web page that I came across that was dedicated solely to the 89 Turbo TA said that it too came factory with the Dana 44. If I can find that page again I will post it here. It is hard to conferm this since those cars are rare and I have never seen one. I was just wondering if it was an option on a standard firebird camaro, Z28, Trans Am or anything F-body and what years? I do think that theses sources can be considered reliable especially since one of them is SLP and they designed it.
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
If you can wait until spring, DTS is coming out with a Dana rear for third gens. It will be about 25% cheaper than the 9 inchers from Mosers.
Gotta love the PRI show
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
www.koolmeister.com
Miles
88 427 Camaro
www.koolmeister.com
Engine: 383 Carb
Transmission: 4L60
I wasn't disputing that it came on the Firehawks, just that I don't consider those "factory" cars.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I know three people with TTA's, and they have the 3.27 ratio 9-bolt, not a Dana 44.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Engine: 383 Carb
Transmission: 4L60
DTS is http://www.drivetrain.com, isn't it?
www.drivetrainspecialists.com
toll free 1-877-874-7327
here are some others
currie enterprises
www.currieenterprise.com
714-528-6957
strange eng 1-847-869-7010
slp used to have danna 44s
732--349-2109
www.slponline.com
currie enterprises
714-528-6957
732--349-2109
www.slponline.com
Sorry, I stand corrected. The turbo TA came mostly with the 9 bolts. I think they were just talking about the indy pace cars for that year. I could be wrong about that too. Thanks to all those who gave me the webs sites for Dana 44 distrubitors.
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
Not that this answer any of your questions.
About 2 years ago, I was looking for a replacement rear for my '89 IROC. Well my grandfather works for Dana and I had him do some checking around, because I saw the Dana 44 listed in a '96 GMPP catalog.
According to his sources at Dana, there were some 44s in early 3rd Gen F-bodies. Also that SLP had bought all the remaining stock of the 44s in '96 or '97 (that's why GMPP quit offering them).
Sparks a flyin'.
Sparks a flyin'.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If I blow up my diff next year, I want to go to a 9" but if I can get a 8.5 dana44 cheaper, it would be sufficient for me.
Apeiron: Let me know if you ever want to part with yours. MMMM Ya. Your car would look real good with my 9 bolt sitting under it. 3.27 gears, posi, disk brakes.
You can come and have a look at it if you want.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
[This message has been edited by Stephen 87 IROC (edited December 06, 2000).]
You can come and have a look at it if you want.------------------
Best 60 foot: 1.662
87 IROC bracket car
95 Homebuilt Harley
Engine: 383 Carb
Transmission: 4L60
Yeah I'll keep that in mind.
Send me an e-mail sometime though, we'll have a beer and talk about cars.
Engine: 383 Carb
Transmission: 4L60
Just in case anyone's interested, too, the numbers I have for the GMPP Dana 44 axles were 14044853, 14044854 and 14044855. Don't have ratios for those unfortunately.
GMPP still stocks ring and pinion assemblies for them too:
3.31:1 - 14044859
3.92:1 - 14044863
4.09:1 - 14044864
3.31:1 - 14044859
3.92:1 - 14044863
4.09:1 - 14044864
Car: 87 IROC L98
Only trouble is, that 2.73 carrier of yours has very few gear ratios available. Richmond offers a 3.73 as the lowest gears for that carrier. If it was 3.73 gears instead of 2.73's then the lowest gear set available is 5.89.
Toms Differentials lists a thick 4.10 gear for a 3 series carrier (2.72-3.73). A 4 series carrier is 3.92 and up and a 4 series spool is available.
There's an e-mail address on my IROC web page.
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Are those part numbers for just the axles (why 3 numbers) or are they for the whole rear axle housing?
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm
Engine: 383 Carb
Transmission: 4L60
As far as I know, they were for the complete assemblies.
Engine: 383 Carb
Transmission: 4L60
While we're on the subject, Stephen, who can I trust in town to swap gears in that thing for me?
Engine: 4.0L
Those part numbers, the last two are for gear sets. They are still available from http://www.gmpartsdirect.com for around $275.
So they are not for complete assemblys..
86 Camaro Sport
Car: 87 IROC L98
I did my own. Unlimited Performance will do it for you. They do a lot of the race cars and they set up the rear ends with pinion depth guages.
Engine: 383 Carb
Transmission: 4L60
Ok, I'll give them a call. I haven't dealt much with the shops in town since I've been here, had my car on the dyno at Davenport but that's about it.
John, I just tried looking on gmpartsdirect.com and shows all three numbers are "not found".
Engine: 4.0L
Has anyone done a globle search for the Dana 44 F-body axles with those part numbers?
86 Camaro Sport
Car: 87 IROC L98
I did a search on drive train direct's site. They list axles for just about everything but nothing for the third gen dana44. They'll make a custom set if you need them but I don't thing anyone here including myself will hurt the stock 30 spline axles. Maybe if you're running 600+ hp and using a tranny brake to launch at 4000+ rpm.
I was under the impression that the DANA 44 was also used as a warranty replacement for the BW 9 bolt.
Black 89 IROC...Mods: 355, 10.5:1 comp, Big Solid Crower Cam, TFS heads, Victor Jr, Holley, and a 5 spd...
sailtexas186548
Jan 19, 2016 12:21 PM
