shudder?
Old Aug 30, 2008 | 07:22 PM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
shudder?
If I hit the gas hard sometimes the drivetrain will shudder for a second before the power really engages.
Obviously something is wrong, but what?
Tranny?
Torque converter?
Gears?
I did search but obviously (shudder) is a kinda vague keyword...
I have no other noises or shifting issues at all and car drives fine the rest of the time.
any suggestions would be appreciated, thanks
Old Aug 30, 2008 | 08:24 PM
87IROC92RS's Avatar
Car: 87 IROC
Transmission: built 700R4
Axle/Gears: 3:27 posi
Re: shudder?
my 92 used to do that especially when accelerating on turns but occasionally on straight line launches as well. I installed a tranny cooler for the 700R4 and tightened the torsion bars up and the shudder went away for me. Hope this might help ya
Old Aug 30, 2008 | 08:35 PM
Car: 92 Camaro RS
Axle/Gears: Stock
Re: shudder?
yes it IS worse while turning!
Thanks I'll look into that any recommendations on where to get the parts?
Old Aug 31, 2008 | 07:21 AM
Car: 92 Camaro RS
Axle/Gears: Stock
Re: shudder?
OK, after thinking about it I have no idea how either of those things would help?
A cooler would only help if the problem only happened when hot, but it happens cold too.
And I understand how torsion bars MAY cause a shudder, BUT the shudder I am talking about is clearly preventing the power from hitting the wheels, so again I don't see how that could be it??
Old Sep 2, 2008 | 04:15 PM
Car: 92 Camaro RS
Axle/Gears: Stock
Re: shudder?
well after paying attention a little more I have noticed this only seems to happen while DOWNSHIFTING (when u floor it at cruising speed etc).
Anyone else have any ideas or similar problems?
Old Sep 4, 2008 | 01:13 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: shudder?
front or back wheels?
Old Sep 4, 2008 | 01:10 PM
Davemutt's Avatar
Re: shudder?
Sounds like your TV cable may be bad or out of adjustment.
Old Sep 4, 2008 | 01:24 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: shudder?
Wheel bearings maybe.
Old Sep 4, 2008 | 02:41 PM
Car: 92 Camaro RS
Axle/Gears: Stock
Re: shudder?
Thanks guys.
Turns out my pan gasket sprung a good leak since I last checked the fluid (which was recent) so little to no fluid is always gonna cause problems! LOL
Feels like a new trans now
Old Sep 4, 2008 | 03:00 PM
87IROC92RS's Avatar
Car: 87 IROC
Re: shudder?
glad to hear you figured it out... I neglected to say when I installed the cooler my tranny had a leak as well so I replaced the filter and gasket...... and yes fluid always helps mechanical parts work better lol
Old Sep 4, 2008 | 03:54 PM
Car: 92 Camaro RS
Axle/Gears: Stock
Re: shudder?
Thanks 87. I have to keep reminding myself, check the cheapest and simplest things first, they are usually the fix! LOL
Now I can go back to thinking about fun stuff, like some nice loud side exhaust dumps )
mfp189
Sep 27, 2015 09:25 AM
novaderrik
Aug 10, 2015 12:44 PM
91CamaroRS305
Feb 12, 2003 12:26 PM
spearson
Jan 8, 2003 09:13 PM
Rig
Apr 23, 2001 06:22 PM
