tranny question
Old Sep 1, 2008 | 09:21 PM
bkcamaro's Avatar
Car: 85 z-28 and 96 z-28
Engine: 383 storker and a 350LT1
Transmission: 700R4 and 4L60E
Axle/Gears: 3.23 and 3.73
tranny question
ok i have an 85 z28 with a 700r4 with a b&m shift kit and rachit shifter. i am pulling the motor and trany for a 383 with a built th350. there is nothing wrong with the trany and the trany in my 96 v-8 camaro is bad and that has a 4L60E what do i need for the swap from the 4L60E to the 700r4 the 96 is my main driving car so i need overdrive thats the only reason i am considering the 700r4 for my 96
Old Sep 1, 2008 | 11:06 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: trany ?
well the computer controls the converter lock up and line pressures in the 4L60 so if you put the 700 in the computer isn't likely to be happy about it. Internally they're more or less the same but to have a working lockup you would have to install a manual switch, then get a VSS for the 700 so you would have a read for the speedo and a speed input for the computer. So long story short if it's a bad idea to try and put that 700 in your 4th gen. In the end I wouldn't be surprised if you spent almost as much money getting the 700 setup in the car as it would to take the tranny to a rebuilder.
Old Sep 1, 2008 | 11:07 PM
bkcamaro's Avatar
Re: trany ?
thanks
Old Sep 10, 2008 | 03:41 PM
bkcamaro's Avatar
Re: trany ?
ok so i went to get a price on a rebuild. 1500 and thats with the trany out of the car and me putting it in and no touqrconverter. and i just cant put in a stock trany cuz the car has over 10000 dollars of add ons and motor work done to the car. so i priced around not much cheaper at anyother place i went to and two of the places said its not just my trany but my computer to. one person said a chip would fix that problem and that coast about 400 just for the chip. and a short time later my trany went to hell i lost 2 3 and 4th so now my 4500 dollar car ant so hot anymore and i am a little pissed that i could cost my over 2000 to get it back on the road. so please help.
Old Sep 10, 2008 | 06:41 PM
WIll36's Avatar
Engine: 355, 408
Re: trany ?
just out of curiousity what's the milage on the car and what exactly have you done to the motor?
Old Sep 11, 2008 | 06:44 AM
bkcamaro's Avatar
Re: trany ?
130000 miles on the car and the trany thats in the car has been rebuilt several times by the past owner. motor work well full slp loud mouth exsost, injecters, pistons, programed, rear end work, cold air intake thats just the stuff off the top of my head. i havent done anything to the motor my self this is all stuff the past owner put on it and he builds drag cars and he owns his own machean shop. there is $10000 worth of reseats in the glove box to show most of the work done to the car
Old Sep 15, 2008 | 12:00 PM
WIll36's Avatar
Engine: 355, 408
Re: tranny question
So were the motor and tranny already rebuilt? Does it have the stock head and cam package..... from what you have on that list it looks like the motor needed a rebuild and he might have put in some higher compression piston and done some normal bolt ons too. Also the rear axles in those cars aren't known for their longevity so that needing a rebuild it's too surprising even for a stock vehicle with that milage on it, if some track use or hard driving has been done. Anyway if the motor is more or less stock(head and cam package) a stock rebuilt tranny should be ok. I would just use the basic monster kit.
Old Sep 15, 2008 | 01:52 PM
bkcamaro's Avatar
Re: tranny question
the past owner rebuilt the motor at 110000 miles its got after market pistions in it i dont know about heads and cam tho i need to ask him. but even then if the motor needs a rebuild what would that play in my trany not holding up
Old Sep 16, 2008 | 05:04 PM
WIll36's Avatar
Engine: 355, 408
Re: tranny question
Sorry I wasn't trying to imply that there would be any need to rebuild the motor again. I was just trying to get a better picture as to what exactly has been done to the car already. The best thing to do would be to fing out exactly what was replaced in the tranny and whether the engine needed a rebuild and the tranny was refreshed or vic versa. But if the motor has a stock head and cam package and will stay that way a basic rebuild should be ok provided the hard parts and components not included in the class were alright. If I remember correctly the line pressure and shift points are whats dictated by the ECM so if it's slipping all around it could be an issue. I would find out exactly what was done on the rebuild and go from there.
Old Sep 17, 2008 | 06:16 AM
bkcamaro's Avatar
Re: tranny question
well the guy gave me some of the receipts and one was for a transmission overhaul kit, torque converter and trans fluid. description of what had been done to the trany "r&r transmission, disassemble and inspect, rebuild transmission, replace torque converter, hot flush trans cooler, test drive and adjust as needed, and install z pack update" one year warranty ended in 4/26/07 and this was all done to the car at 111850 miles on the car. at american auto transmission on 1744 s ashland ave greenbay wi 54304
Old Sep 17, 2008 | 05:16 PM
WIll36's Avatar
Engine: 355, 408
Re: tranny question
Seems like there was a full rebuild done so you shouldn't have a failure unless the car has been severely abused. What are the symptoms exactly?
Old Sep 18, 2008 | 05:58 AM
bkcamaro's Avatar
Re: tranny question
well i talk off from the line and it holds the rpms and wont shift into 2nd unless i let off the gas at 2500 or higher rpms and now i dont have 2nd 3rd or 4th i am getting a used trany but i am worried that the computer might be the problem
Old Oct 15, 2008 | 04:19 PM
bkcamaro's Avatar
Re: tranny question
ok i bit the bullet and had my trany rebuilt new torqr converter and a shift kit installed. well now the car moves but the problem is still there so i am now thinking it might be my computer. i found a web sight https://www.700r4l60e.com/store/home.php?cat=64 and this is what it says ""This Street/Strip (Full Manual) Shift kit allows you to select the firmness you desire, and you can hold any gear to any rpm, or backshift to any gear. Comes with vacuum modulator. For transplant or use with no electrical (computer). This kit is matched to your particular motor, torque converter, rear end gear ratio, etc., and how you drive. So when ordering, make sure you fill out the questionaire, so that I can match this kit to your particular vehicle & driving requirements. This "modified" Shift kit offers additional information, eight Torlon checkballs to replace the steel checkballs that damage the valve body separator plate, valve body gaskets, Viton D-rings for the Corvette servo, and EPC solenoid filter. This kit allows you to hold any gear to any rpm, or backshift to any gear. 10" or smaller torque converter recommended here for the best results. LS1''s & 1994-1996 Impala''s already have the Corvette servo. If you do not already have the Corvette servo, I would add one now, or the Sonnax 1-2 servo. See LS1-4L60E Upgrades for this."" they are asking about $200 for it and i was wondering if this could fix my problem
Old Oct 19, 2008 | 08:13 PM
bkcamaro's Avatar
Re: tranny question
today i was driving and i could smell burning trany fluid so i polled over to the nearest gas station can looked for leaks none then checked fluid level its good and it didnt smell burnt. i smelled it before after he did the trany swap so i figered that some got on the exsost cuz i make a mess when droping the trany but its been three weeks since then and i still smell it and i know thats not good so what duz these exactly mean
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
