Is it true you can use a torque converter from a V6 S10?
Car: 1992 Firebird
Transmission: 700R4 with B&M shift kit
Axle/Gears: 3.23 zexel 4th gen
I remember hearing somewhere, probably on these boards, that you can swap a torque converter from a v6 s10 into your car in place of the stock one. The reason being is it has a higher stall ratio but I want this verified before I go out and do it. Also, can it handle the same horsepower/torque?
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: Is it true you can use a torque converter from a V6 S10?
A 4.3 S-series converter will stall higher behind a V8.
http://indipalass.com/ARCHIVE/TechCo...%20Upgrade.htm
Not much, but definately an inexpensive trick.
dont bother with the s-10 converter they are fine for all motor v6 guys and stall pretty damn high behind a v6.
i broke 5 of those stock s-10 units behind my old 2.8L v6 with a turbo running 7psi. which prolly made the same power as a stock 350tpi motor
Car: 1983 G20 Chevy
Transmission: 4L60
First off a 4.3 torque converter is not going to bolt to a 2.8, nor will it fit inside the bellhousing of a 60* V6 transmission. I've run a 4.3 S10 converter behind a modified 350 Vortec in an Express van.
Car: 83 Z28
Axle/Gears: 4:11:1
a frend of mine told me the same thing !!!! but he said after about 3 months you will have to replace it !! he had it behind a modified small block(408 i belive)
doh i got my head stuck inthe small v6 world, ther converters i was using was out of the 60* powered s-10s.not the 4.3's
Car: 1992 Firebird
Hmm... thanks guys this is a lot of good info. It sounds kind of iffy though if they will be able to put up with my abuse. I think I might look on ebay and try one of the stall converters on there. Anybody heard anything about those?
speedingpenguin
Apr 15, 2005 10:07 AM
