Is there a difference in flywheels in pre-87 700R4 cars as opposed to post-87 cars?
Old Dec 16, 2000 | 06:36 PM
MILT's Avatar
Just curious. I may buy an '83 HO 'Maro, and want to put in my "newer spline-style" B&M tranny and converter.
MILT
"Without evil there can be no good, so it must be good to be evil some time!"
Old Dec 16, 2000 | 07:36 PM
ede's Avatar
ede
yep the flywheels or flex plates on the engines with one piece rear main seals have a weight because of the missing metal from the flange on the back of the crank. it's not really a weight but it does act as one so they had to add a weight on the flex plate to compensate for the missing flange.
ICON Motorsports
1st & 3rd
Old Dec 16, 2000 | 09:37 PM
84FTA's Avatar
The post 87's have counter balancing much like what is used on the SBC 400 (because the increased stroke of the 400 leaves less room for the counterweights on the crank). Post 87's also have a 3" mounting flange while pre-87's have a 3.58" mount flange which makes it much strong and much better suited for a high perf. applications. Flexplates are cheap and readily avaible at most autoparts stores.
Oh, and to answer your question. The current flywheel should work unless the new convertor requires a 14" flexplate, again, readily avaible.
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 WS6 Trans Am T-top car
4-bolt main 350, headers, Holley 650, T-5 and 3.23's.
Daily driver and restoration
[This message has been edited by 84FTA (edited December 16, 2000).]
Old Dec 20, 2000 | 06:30 PM
86_327_camaro's Avatar
you shouldn't have a problem putting a newer style 700r into an older car. the flywheels are different as stated above but the bolt patterns as far as flywheel-to torque converter are the same. so the newer 700r will line up with an older flywheel
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
TreDeClaw
Aug 14, 2015 06:58 PM
