Gear recommendations
Old Dec 14, 2000 | 09:05 AM
327 firebird's Avatar
I have a 327 dropped into my 85 firebird. I got the richmond 6 speed with 3.27 1st and .76 6th. Richmond recommends a rear of 2.73 to 3.23 What do you guys think about these ratio's or should I ignore their rcommendations and go with something closer to 3.45's I know they recommend this because of the 1st gear for better gas milage ... which I definatly need. But I don't want to lose to much speed. Will I get plenty of accelleration with 2.77? With 3.27's or do I really need 3.45's? What do you guys think? BTW these are all with posi's.
Old Dec 14, 2000 | 01:27 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
well with a .76 6th gear you will be ok if you stay in the 3.42 or 3.45 range. If you do alot of interstate driving going any higher you are going to run fairly hi r's. I wouldnt go any higher than a 3.73 for the street. Kevin
Old Dec 14, 2000 | 07:03 PM
Old Dec 19, 2000 | 11:59 PM
86_327_camaro's Avatar
i'm getting ready to drop a 327 and a new 700r into mine and i think that next summer i'm gonna redo a rear end and go with 3.23's
Old Dec 21, 2000 | 09:27 AM
Hey you will be happy with the 327!! Its a great motor I love mine. I'm also getting 350HP 400 Ft/lbs torque from mine. Didn't go any higher since I will be having a 45 mile journey to work each way! Need to have some gas milage!! I had a 3.42 open diff. I just bought a 9 bolt to better stand up to the motor. I found out later it was a 2.77 and I just bought a 3.27 gars and posi. I don't know of anyone who has the 3.45 who is willing to sell em or they are not broken! I think the 3.27 will be better anyways because of gas milage and I didn't want to lose that much power with the 2.77. For you car the 3.27 would be perfect with the auto though!
Old Dec 22, 2000 | 09:59 PM
82z's Avatar
82z
I don't think there will be much of an advantage to getting a much lower gear than they recomend. 3.27 is pretty lower and with a relatively low gear like a 3.73 you will be very traction poor and you will have to shift sooner and more frequently than you would with a comparatively higher gear. I would definately not go lower than 3.45, 3.27 is a pretty stout first gear. Have fun
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Dec 23, 2000 | 07:29 AM
Thanks for everyones help!
Old Dec 23, 2000 | 11:03 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
With your 3.27 first gear and 3.23s, that gives an equivalent overall first gear ratio similar to a 700R4 with 3.55s while in 1st.
And remember that a 700R4 in 1st gear with 3.23s is similar to TH350 with close to 3.70s. Also, while you are overdriven in 6th, you are not as steeply overdriven as many of todays overdrives. I say 3.23s would be the perfect gears for you.
Old Dec 23, 2000 | 11:08 PM
Thats sounds great looks like I will be swapping in the 3.27 gears and posi for the 2.77 in the 9 bolt I have sitting in the garage as soon as I get the chance. I didn't know that about the TH350 or 700R4. Thanks
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
