Confusing with th700r4 oil capasity
Old Sep 7, 2008 | 09:04 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Shop manual says 10.9 liters after overhaul.My trans takes 7.7 liters after overhaul.Fluid level is checked with hot oil ,car at level and trans at P.Trans has street Edge converter(9.5")which is supposed to be 1.5 quart less fluid volume than original 12" converter.Trans is -89 th700r4 and dipstik and tube are from original -85 th700r4 trans.Is this 7.7 liter fluid volume right or not?
Old Sep 7, 2008 | 12:15 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Re: Confusing with th700r4 oil capasity
Are you accounting for the fluid in the convertor? If it wasn't completely empty, I can see it holding at least a couple of quarts.
Old Sep 7, 2008 | 12:39 PM
z 28 jari's Avatar
Engine: 385
Converter is brand new.I suppose that they delivery it empty.Look into it and it seems dry.
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
camaronils
Sep 20, 2015 02:57 PM
CatmanFS
Sep 19, 2015 09:00 AM
bubbaz28
Sep 18, 2015 02:09 PM
