Confused about my rear
Old Sep 13, 2004 | 04:48 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
For starters picked up a 10 bolt rear out of an 89 Iroc found it for 100 bucks. I had it in my 87 Z28 for about a year and the posi unit went bad so I bought the slp unit before i took out the rear. Today i took the rear to the shop and he told me and i saw that the slp unit was MUCh smaller than the unit in the car. It has 3.54 gears and the PBR brakes, but the thing is i just don't understand why the SLP unit is so much smaller. Anybody go info on what rear this might be? I have to get a new posi unit so the guy can throw it back together for me. Thanks
Old Sep 13, 2004 | 10:06 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
If this is the one that they sell for $99 it is a zexell torsen unit from the 4th gen. They never wear out because they have no clutches. Yeah they look smaller but they fit fine as long as you have 28 spline axles. My 89 WS6 had 26 spline axles so I bought a pair from Moser when when I got the Torsen T2R.
Old Sep 13, 2004 | 11:35 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Yea it is a lot smaller, but the axles and the ring gear don't fit onto it they are too big for the slp unit. I heard something about the austrailian something or other but I thought that was the 9 bolt.
Old Sep 14, 2004 | 09:58 AM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Also I found out today that it has Dana stamped on the ring gear and the posi unit is called a trac lock. The guy at the shop thought it might be from a TTA, but he has never seen one before so he isn't really sure. Anyone have any clue on this?
Old Sep 14, 2004 | 10:45 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Pictures would really help.
Old Sep 14, 2004 | 11:35 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Isn't 3.55:1 a 9-bolt ratio??
EDIT: okay, looks like 3.45:1 is a 9-bolt ratio.. hmmm
Old Sep 14, 2004 | 02:44 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
It's a 3.54...Don't know the ratio numbers as the rear isn't at my house right now but im positive it came out to 3.54. I just don't know what this rear could be. I'm going to try and get a picture of it tomorrow when i go over to the shop. The guy said it looks like a rear out of a TTA, but it isn't a 9 bolt so i didn't think it was.
Old Sep 15, 2004 | 01:21 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Does anyone know if there are rebuild kits for the dana 44's trac lock posi. The dana is the only thing it could be, it has the bolt in axles and its the 30 spline posi unit. I see in the jegs and summit mags there are several different kinds of 8.5'' rears I just don't know which one is the right one.
Old Sep 15, 2004 | 02:17 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
The SLP unit is on the right and the Trac Lok is on the left
Old Sep 15, 2004 | 03:11 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
3.54 is a ratio I had in a Dana 60 years ago, but it was 9 3/4 with 35 spline axles.
Old Sep 15, 2004 | 03:33 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
I took the unit to GM and they couldn't find anything about it. I'm trying to buy the clutch pack for it I just don't want the wrong one. Does any one know of a place i could get them from? Thanks for any help at all
Old Sep 16, 2004 | 03:39 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
post a pic of the cover
Old Sep 16, 2004 | 05:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://www.superioraxle.com/pdffolde...atalog2004.pdf
Try looking through there and see if you can identify it by the number of ring gear bolts and the threads; a pic of the cover would be conclusive; a pic of the whole rear might even help.
Old Sep 16, 2004 | 06:49 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Yea here is the cover, but the housing is at the shop.
Old Sep 16, 2004 | 06:54 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Old Sep 16, 2004 | 08:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's no mistaking that; it's a Dana 44.
Try this for parts http://www.drivetrainspecialists.com...s.php?catid=15
Old Sep 17, 2004 | 01:02 AM
transambill's Avatar
Car: 91 Firebird Formula
Engine: ZZ4 fast burn with TPIS mini ram.
Transmission: Viper T10 6 spd.
WOW, You got a Dana 44 for $100.00
Old Sep 17, 2004 | 02:06 AM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
It was a hundred plus a hundred for the brakes, the guy thought it was just an Iroc rear...so did I. I ordered one of drivetrain.com i think for a trac-lok. I don't know if it's the right one or not. It's part # 706352X.
Old Sep 17, 2004 | 02:23 AM
STILL, Some people will pay upwards of $1000 for a DANA rear.
Old Oct 2, 2004 | 10:43 PM
ross0310's Avatar
trac lock is a mopar/ jeep term check a mopar dealer for the clutch packs or do a search for mopar performance online. they'll have it. if it will fit right id say the dana 44 is a strong rear.
Old Sep 4, 2008 | 01:23 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: Confused about my rear
torsen diffs arent rebuildable like the clutch pack ones are. and if your car is seeing any track duty id say stay away from the zexel. youll break it
Old Sep 4, 2008 | 07:52 PM
Jon92TA's Avatar
Try Toms?
http://www.tomsdifferentials.com/tomp.htm
Old Sep 5, 2008 | 07:58 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Wait...Dana 44s bolt right under 3rd gens?!?!?!
Old Sep 7, 2008 | 01:54 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Old Sep 7, 2008 | 02:12 PM
Stephen's Avatar
Car: 87 GTA
Yes. I believe the Firehawks got 44s, but I'm not sure what else did or might have.
RazorN8
Jan 7, 2022 11:44 AM
lt500r55
Sep 1, 2021 01:30 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
BurlyChev
Aug 22, 2015 01:52 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
