Replacing Pinion seal ?
Old Dec 17, 2000 | 01:48 PM
ede's Avatar
ede
i have a bad pinion seal and was wondering the correct way to reinstall the pinion nut? how do you know when it's tight enough? thanks
ICON Motorsports
1st & 3rd
Old Dec 17, 2000 | 02:05 PM
82camaro's Avatar
Car: 82 camaro SC
until there is no slack in the bearing or a little bit past it's previous position. mark the location before you take it off.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Dec 17, 2000 | 02:08 PM
ede's Avatar
ede
doh that was easy i should of figured that one out my self. only problem was i was going to use a new nut. i'll measure the nuts depth or something to locate it. maybe scribe a line or two to help.
ICON Motorsports
1st & 3rd
Old Dec 17, 2000 | 06:18 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Ede:
I ma having the same problem, how hard was it to get the Nut off the yolk? and did you uses an impact wrench, I don't have one but this leak is driving me crazy.
Brian Felts
Old Dec 22, 2000 | 03:14 PM
ede's Avatar
ede
i usually use 3/4 drive tools for the pinion nut. you'll need to make something to hold the pinion yoke. i have a 4' piece of 3"x5/16 flat bar. i transferd holes for the 12 bolts, old 10 bolts and the 7 1/2 10 bolts. just bolt it to the pinion yoke and put the socket through a hole in the center.
ICON Motorsports
1st & 3rd
Old Dec 26, 2000 | 08:45 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The best way is to measure total preload with a beam style inch pound torque wrench, then when done, retighten untill you get the same abount of preload. The bearings need to be preloaded to keep the pinion from for and aft movement, and since they have been driven for so long with that preload, not getting it close to where it was will have your rearend humming Dixie before you make it around the block. You may use an impact to remove the nut, but NEVER to tighten it, not even to run it down. You will impact load the bearings and they will be shot before you ever finish the job.
Oh yeah, if you have a good sense of feel, you can just turn the companion flange (yoke) before and after to see if they feel the same.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
[This message has been edited by GMTech (edited December 26, 2000).]
Reborn756
Sep 4, 2015 03:42 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
Leggman1
Aug 6, 2015 04:15 AM
