sugg. on ring gear choice.......
Old Dec 26, 2000 | 12:20 AM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
hello again, i need opinions on gear size for my 'ROC. I was going replace the broken 3.42 set with the same size from some aftermarket (prob. richmond) but have a set of free 3.73 out of an 85 4cyl camaro. I know the gears could never have taken a hit that would weaken them from that drivetrain. SOOOOO should i try these 3.73's first??? I can always change them after this race season. Also in the event i do is the right speedo combo "7" drive gear, "21" driven gear? Lastly, who makes a good rear bearing/seal kit?? Thnx alot, look forward to your insight.
'89 SHAGGY IROC
L98 7r4, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc.
so much to do , so little money
Old Dec 26, 2000 | 09:49 AM
ede's Avatar
ede
richmond makes a install kit that has everything you need. you ought to even have a few pieces left over. 3:73 is a good set for street preformance if it's an all out drag car i'd look at 4:56 gears. sorry i don't know about the speedo gears.
ICON Motorsports
1st & 3rd
Old Dec 26, 2000 | 10:36 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Another gear install kit is Ratech.
Speedo gears sound right, that's what my HO car came with, with 3.73s from the factory.
As long as the gears are in good shape, no rust or run dry or anything like that, they should work as well as any in your car.
Old Dec 26, 2000 | 01:00 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Do you have an automatic or a stick? Your sig says "7r4" which I take to mean 700R4 which is an automatic? The 7 tooth and 21 tooth gears are for stick shifts. I think the ratio is 15 and 45 for an automatic and 3.73 gears.
Do you have a 9-bolt or 10-bolt rear end? 89 cars came with 9-bolts, and 10-bolt gears wont fit.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 26, 2000 | 02:32 PM
let me clear things up.
1. it was a 9 bolt now a 10 bolt
2.yes i have an auto trans and will be keeping it.
3. it is going to be street driven, some track time.
4.also is the mileage difference between 3.42 and 3.73 going to be big?
and lastly for those with 3.73" what is your traction and rpm at cruise like????
'89 SHAGGY IROC
Old Dec 27, 2000 | 06:56 PM
bttt
'89 SHAGGY IROC
F-body driver
Mar 6, 2023 11:44 AM
db057
Apr 28, 2019 07:45 AM
Fronzizzle
Sep 8, 2015 12:10 PM
BOOT77
Sep 5, 2015 03:55 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
