200C to 700R4 swap?
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
200C to 700R4 swap?
is it hard to do a 200C to 700R4 swap. i hate my 3-speed. i get about 13.9 mpg on the freeway. i want more. so, is it hard or does it just pop in. thanks in advance.
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
Eldebrock Headers, 3" Hooker Cat-Back, duel outlet with quad tips.
Mods: 1.6 Proform Roller Rockers, electric fan, Corvette 5.7L CFI computer chip, K&Ns.
Audio: JVC Kameleon CD deck, Jenson 4x6 front, Eclipes 6x9 rear, 2 10" mTx T4000 powered by a mTx 200watt amp.
RED82TA5.7L
Nah, not too bad. But I'd HATE to waste the time if I were you. I had NOTHING but problems with my 700R-4......replaced it 4 times, then swapped in a 6-speed. Don't get me wrong, if you get a QUALITY 700R-4 (not from a local rebuild shop)......like one from Art Carr (even though I've heard some bad things from there too), or better yet, Pro-Built (never heard a bad thing there)....you should be good. But plan on spending some $$$$$. Personally, I like to bang through the gears.
Kelly
If you've gotta fix it, fix it better than stock.
Kelly
Engine: LT1/350 TPI
thanks for the reply, im getting one out of a junk yard and me and my dad are going to rebuild it. we ordered a book in jegs on how to rebuild a 700R4. thanks again.
RED82TA5.7L
RED82TA5.7L
OOOOOOOHHHHHHH, damn man.....I rebuilt one on my own, and I'm not gonna lie...it's a PITA if you don't have the necessary tools. You can do it though. The only advice I have is lay everything out on the floor exactly as you took it apart, that way, there's no question what goes where. And take your time too, don't rush it. And, if your girlfriend pisses you off some night, don't fly over a nasty dip at 80 MPH and rip out your tranny cooler lines, running your tranny dry and ruining all that work you put into her (the tranny, not your girlfriend). Cars are way more important than women, never take it out on your car. Don't floor the throttle, floor the woman (oh, I'm goin on a rant here). While you got it apart though, build it MEAN, find the part # for that kickdown switch they put in police camaros that lets the tranny shift to OD at WOT. Alotta guys on this site know the #, just ask (it's cheap too).
Good luck,
Kelly
Good luck,
Kelly
Engine: LT1/350 TPI
thanks for the advice. ill do what you said about laying the parts in order. thanks again.. oh, and i dont have to worry about women yet. i dont have a girlfriend
RED82TA5.7L
RED82TA5.7L
They arent that bad. ( Gf's )
as for the 700R< Mine is still breathing, So I cant Comment.
60 Ranchero - Project ( Money Hole )
85 Z28 LG4 - Daily Driver
**Mods**
MSD Superconductors
14" Open Element
KYB all around
**Mods**
MSD Superconductors
14" Open Element
KYB all around
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Make sure you get a later model 700R4. The early ones are garbage, the later ones are pretty decent but can still be made stronger.
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 383 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
Car: 82 camaro SC
The 700r4 is about 3 inches longer than the 200c. A shorter driveshaft will be needed(junk-yard for about 40 bucks). The crossmember won't work because it needs to be moved toward the back of the car a few inches. The holes aren't drilled and tapped to move the crossmember back. Modification is necessary(I modified mine my cutting and welding the existing crossmember). The shifter won't handle the tranny having 4 gears instead of three, a later model shifter or aftermarket should be used(I used a B&M Megashifter. You may need a lockup kit depending on if you have a computer and if the computer will control the 700r4. The crossmember is the biggest problem. The 700r4 isn't a bolt in installation, but it can be done. The overdrive is worth the effort. My cruise rpm went from 3000rpm at 60mph to 2100rpm at 60. I would do a stock rebuild and install the vette servo and .5 tv boost valve, both are simple--especially if you have the tranny apart, and will make it shift very nice.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
[This message has been edited by 82camaro (edited December 11, 2000).]
82camaro
Engine: LT1/350 TPI
thanks for the replys. 82camaro, you used to do 3000 at 60. man, i do 2600 at 60 and 2900 at 70. man. after your reply i might have someone do the swap.
RED82TA5.7L
RED82TA5.7L
Engine: LT1/350 TPI
oh, and i thought the 700R4 is vacumed controled. i didnt know the computer controls the tranny exept for the 4L60 and later..
RED82TA5.7L
RED82TA5.7L
Car: 82 camaro SC
The computer only controls the lock-up of the converter on the 700r4/4L60, not the shifting. 4L60-E has the shifting controlled electronicly. The 700r4/4L60/4L60-E is it no way controlled by vacuum.
It was not fun with 3.73's and no overdrive on the highway, the interstate at 75 was even worse.
82camaro
82camaro
Engine: LT1/350 TPI
ok. now i get it... yea, i have 3.23 rear gears
RED82TA5.7L
RED82TA5.7L
You can get lockup switches easily. Don't worry about that part. The driveshaft...eh, gonna hafta have it. If you and your dad can rebuild one, you can easily swap it out. Hell, when I go home next week for the break, I'll look around the garage and basement and see if I can find my old shifter and junk. If it's still there, I'll send it to ya free (if you pay the shipping). I'm always willing to lend a hand to a fellow swapper. Don't give up.
Kelly
Kelly
Engine: LT1/350 TPI
hey thanks IROCracer . i will talk to my dad tonight about that shifter and ill send you an e-mail.
RED82TA5.7L
Mods: 1.6 Proform Roller Rockers, electric fan, Corvette 5.7L computer chip, K&Ns.
RED82TA5.7L
Car: 82 camaro SC
Don't toss your old driveshaft. Somebody on this board will want it because it's the correct length for a standard length th350(6 inch tailshaft).
82camaro
82camaro
Engine: LT1/350 TPI
ok. ill keep it. and if someone is in trouble. ill give it to them.
RED82TA5.7L
RED82TA5.7L
Car: 92 RS
Engine: 396 sbc
Transmission: t5
Red I am in desperate need of your driveshaft
I have looked from here to there for one!
Can you please email me! I would love to take it off your hands!
In fact I will swap you a 700r4 driveshaft for yours!
Please mail me asap!
By the way you have mail also
[This message has been edited by 85cam (edited December 19, 2000).]
Engine: LT1/350 TPI
turns out im not getting a 700R4. im getting a TH350. the 700R4 costs more and it needs modification. so i figured the TH350 would be better on my wallet. in the next couple of years i want to get a 5 or 6-speed anyway
RED82TA5.7L
this car has a bad tranny untill middle of January 2001(im crying inside)
Black Powder Coated 1990 16x8 Formula Wheels with 245/50/ZR16 Perelli P7000.
For Pictures go to
http://members.theglobe.com/transamguy/EXP_SITE_PERSONAL_2/
RED82TA5.7L
For Pictures go to
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Hey dude! I put a TH700R4 in my '82Z. It wasn't too bad. And I know you are concerned about the initial cost. But I am only turning 2200 RPM @ 70Mph. The overdrive is great. I have also found a very cheap way to use the stock 700R4 crossmember without any cutting or welding. As for shifters. I would go for the B&M Megashifter,for safety sake.
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter. 9bolt 3.27 w/1LE rear brakes 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side not too bad
Engine: LT1/350 TPI
well, my dad is helping paying for it and he dont want to pay an extra $500 on the 700R4. i found a bullet proof 700R4 for $1300 and i found a bullet proof TH350 for $900. both come with converters. and of course, my dad is going with the cheaper one. i really dont care. i just want my car back on the road. the tranny blew 1 week ago and i already miss it.
RED82TA5.7L
For Pictures go to
RED82TA5.7L
For Pictures go to
Car: 1982 Z-28
The extra gas you are going to burn will quickly add up to and then overtake the $1300 dollar transmission.Because the TH350 or TH400 do not have overdrive. Just a thought! I have a '69 Chevelle SS396 w/TH400. And I am, going to install a TH700R4 just to reduce the engine rpm at highway speeds.
Engine: LT1/350 TPI
i know the TH350 has no overdrive. its just going to be more work to get the 700R4 in.
Me and my boss are going to do the swap and i still have to pay him. and its going to be more with the 700R4 because of modification. we just dont have the money. we dont even have the money for Any tranny. we are borrowing money from a friend and we dont want to borrow more then we NEED. and can you beleive that my TH200C blew on Christmas Day.
RED82TA5.7L
For Pictures go to
RED82TA5.7L
For Pictures go to
C409
Sep 1, 2015 03:42 PM
3rdgenparts
Aug 6, 2015 09:03 AM
1983, 1984, 200, 200c, 700r4, 82, camaro, conversion, convert, driveshaft, interchange, jegs, swap, trans, transmission, turbo
