700R-4 dipstick tube attachment?
Old Dec 31, 2000 | 04:27 PM
Tom Keliher's Avatar
To make it easy on myself I will ask this here first before I go out and try pulling it out.
Is the dipstick tube on a 700R-4 tranny, in a L98 TPI powered car attached to anything besides being plugged into the tranny itself? Is the tube possibly bolted to the cylinder head? I forget what it looked like when I did my head swap 1 1/2 years ago and now I am removing my trans and need to know if I just jerk the tube out or if I have to look for a nut attachment somewhere. I'm taking a break and thought I would check with you guys first. Thanks!
Old Dec 31, 2000 | 04:31 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If I remember correctly, it shares a bellhousing bolt. But yes, there is one attachment point.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Dec 31, 2000 | 04:33 PM
Thanks GMT! I will look for that.
Old Dec 31, 2000 | 04:46 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
That is correct, and getting it out ain't that bad, but it's a PITA going back in cuz you got a wire harness bracket attached to that same point... I have small arms and it was still a pain for me...
KAM
Old Dec 31, 2000 | 09:49 PM
GMT, you were correct. It is attached at the top right bellhousing bolt.
thunderstick, do like the tranny shop that did my converter swap a few years ago did: leave the wire harness clamp off! I discovered that today. The wire harnes was not bolted to the trans. And, 3 of 6 bellhousing bolts had backed off!
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
my86bird
Oct 23, 2015 12:20 PM
86IROC112
Oct 9, 2015 10:38 PM
75bike
Sep 20, 2015 09:37 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
