t56 swap and reverse lock out
Car: 1989 Gta
Engine: 383
i'm at the end of my swap now and i'm waiting for my dakota digital and vss sensor plug. Do i need to do any thing with the reverse lock out? Or can i just wire up wiring to the parking brake so i can't open my hatch at 60 mph?
thanks for viewing
thanks for viewing
Car: '91 TA vert
Engine: turboLSx
Re: t56 swap and reverse lock out
I'd hook the reverse lockout up at least. Makes it easier to shift into reverse when you want to. I mean, why not?
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
i bought my car with a t56, no reverse lockout was hooked up, i though it would be nice to have, put it on a seperat switch, but never used it because its not hard to push past the soliniod, and wiring it to the brake switch is different i know, but i kind of like having to push past the solinoid, lets me know im IN reverse, and its impossible to hit reverse instead of 5th. well thats my 2 cents
Car: 1987 Firebird
Engine: 355
If you plan to wire up the reverse lockout, do it now, or you'll never get to it later.
It can get a lil annoying fighting the solenoid, but i dont mind it. Its not too bad.
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
i kind of like having to push past the solenoid, lets me know i'm IN reverse, and its impossible to hit reverse instead of 5th.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Pushing past the spring is a little tougher then these guys are telling you, what I did was take the unit apart and cut a coil off the spring. Could have been coil and a half you would have search my previous post on this years ago but just make sure not to cut off to much or it will be to soft. After this is done you will be able to shift it without using two hands
Car: 1989 Gta
Engine: 383
right now as it sits with out the engine running will this be as hard as it gets to put the tranny in reverse?
If so i can deal with it now.
Car: '91 TA vert
Engine: turboLSx
Why not just hook 12v to it? I don't understand why so many people are not hooking it up. It's not like it makes you less of a he-man to power up the lockout solenoid. Takes all of 10 minutes to wire into the brake light switch or something similar.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, hooking it up to the brake light switch at the brake pedal is what I recommend.
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
