are the reinforced rearend covers worth it?
Old Jan 6, 2001 | 10:39 AM
bad camaro RS's Avatar
i keep seeing these rearend covers that are suppose to make rearend stronger they have bolts that screw down on your main bearing caps do they work? are they worth the $150
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit
new best ET 13.5 @104.66
Old Jan 6, 2001 | 11:00 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Yes they work. They increase the fluid capacity, they make the rear opening stronger since the cast aluminum is stronger than the stamped tin. The bolts that go against the pinion caps are only torqued to 5 pounds. When you accellerate the pinion wants to push the ring gear out the back of the diff. The bearing caps hold it in. With the added reinforcment of the cover bolts, there's less chance of the gears failing. It just reduces the stress on the bearing cap bolts.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jan 6, 2001 | 11:03 AM
ede's Avatar
ede
you can gain some extra strength by welding the axle tubes to the center section as well.
ICON Motorsports
1st & 3rd
Old Jan 7, 2001 | 08:50 PM
bottlefed89's Avatar
the LPW case works great they also make a brace that will help eliminate housing twist
they have an ad in the back of super chevy mags if you cant find em email me i have his number
Old Jan 7, 2001 | 09:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I have the LPW cover but don't have the braces yet.
Old Jan 7, 2001 | 09:38 PM
ede's Avatar
ede
i too have the lpw cover but not the braces yet
ICON Motorsports
1st & 3rd
Old Jan 8, 2001 | 01:33 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I have the LPW and I have the braces for the LPW. This is the best cover on the market that I know of. We'll see how long it lasts after I finish my most recent upgrades. This rearend held up fine with the 2800 stall Vigilante and 1.7x short times. We'll see how it holds up to the 3600 stall and probably 1.6x short times
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Jan 8, 2001 | 08:03 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Got enough jack stands under that car?
I'll put my diff to the real test this spring with the new big block. I never really got to test it with the small block. I blew up the engine the first weekend after I installed the diff.
Are the brace kits generic or is there a kit specific to third gen? I know that mount on the right side will get in the way to install the brace to the end of the axle. It's hard to tell from the pic exactly where it's mounting to.
wigmobile
Feb 26, 2025 02:56 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Sep 16, 2015 12:37 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
