9" rear housing
Old Jan 3, 2001 | 10:02 AM
gliderguider
Guest
Posts: n/a
9" rear housing
how wide should i have my housing built I want to be able to run wider tires and don't mind some sheet metal work. I will stick with the factory style suspension but with stronger parts. my car is under about 6 feet of snow and i can't get the factory measurments from the thing gm calls a rear end housing my v6 broke it.
Old Jan 3, 2001 | 10:32 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You're throwing a 9 inch under a v6 powered car?? Wow. Do you have plans for a motor swap? My v6 hasn't busted an axle at all; of course I do yearly gear oil changes, that might have something to do with it.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jan 3, 2001 | 11:13 AM
SteveSpohn's Avatar
We carry the Moser Engineering Ford 9" housings. They are torque arm ready.
Just the housing is $460.00
Or you can get a package that includes the housing and Moser axles, bearings, and 1/2" or 7/16" studs for $795.00.
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Old Jan 3, 2001 | 08:54 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Hmmm. Everything except brakes and the third member. If I destroy my diff with the big block this year I'll probably pick up that package. Lots of 9" third members around here. What brakes can be used on that package? Can stock f-body disks be used or do they need a ford brake system?
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jan 3, 2001 | 10:12 PM
gliderguider
Guest
Posts: n/a
I have the third member and axles as well as disc brakes from my stepbrother all for free and yes the new motor is on the stand. the local drag track is six miles away and lots of vht and two turbos off of a 2.2 dodge can make a v6 sing the 700r4 went the same day. all i want is the numbers but if my name isn't lingfelter you think you can give me a hard time fine i will call the boneyard
Old Jan 4, 2001 | 01:52 AM
Bort62's Avatar
haha sweet a Twin Turbo V6
Is that Egg On your face TomP ?
j/k bro
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
Old Jan 4, 2001 | 06:16 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
You can use the stock f-body brake system. You just need to machine a counterbore on the backing plates and redrill it for the Ford axle housing flanges. This will also double as the axle retainer. I don't remember the dimensions for the counterbore but the instructions will tell you how to do this.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Jan 4, 2001 | 09:16 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
A twin turbo v6? There's no egg on my face, because I don't believe it for a second. If he brings up pictures, then I'll believe it. I've heard too much worthless BS spouted around about twin-turbo'ing and supercharging the 2.8/3.1 motors that I refuse 100% to believe anybody's done this to their f-body. I also think that a stock twin-turbo'd v6 would've spun itself into oblivion. I also think that if he had such easy access to a junkyard, and could get the TT job done for cheap, then he would've done a supercharged v8.
Old Jan 4, 2001 | 11:44 PM
Zee's Avatar
Zee
Made mine but Currie sells the caliper backing plates for either the iron (early) or aluminim (late) brakes. $139/pr.
GM still sells the late plates for about $15ea.
Old Jan 4, 2001 | 11:51 PM
Hi-psi's Avatar
Guys,
Don't you have to shorten the driveshaft a little after going to the 9" also? Not to mention adapting the GM driveshaft to the Ford yoke on the third member.
Robert
'89 Turbo Trans Am
#799 of 1555
11.96 @ 109.11 w/1.62 60ft BEST Race Gas
12.53 @ 105.31 w/1.74 60ft.BEST Pump Gas
www.Hi-psi.com
Old Jan 5, 2001 | 07:10 AM
IROCZZ3's Avatar
Car: 87 Buick GN
No, you don't need to shorten the driveshaft...mine is the stock length and works fine. I don't remember the part number, but I use a Spicer U joint to connect the driveshaft to the Ford pinion yoke.
Old Jan 8, 2001 | 11:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
If I can adapt my current brakes then the package looks ever more appealing.
I agree with the spicer u-joint. It's not as strong as a new larger yoke but the conversion u-joint is available. I had a similar one in my old chev 4x4. Large spider yoke on the diff and small spider yoke on the driveshaft. It was the first time I found out about such a u-joint. With so many 9" diffs under chevys, the u-joint manufactures would be crazy not to create a simple way of joining the 2 yokes.
Steve: There's nothing on your site yet about having the Moser stuff.
I'm assuming the Moser housing uses the large style axle bearings?
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
E Rod
Aug 28, 2015 05:17 AM
madsv1000
Aug 20, 2015 06:45 AM
