question about 3rd gen rear ends???
Old Sep 22, 2008 | 01:01 AM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
what are the measurements from wheel mounting face to other wheel face?
also i was wondering what rear end a car im thinking about getting has...
1988 GTA, 350tpi auto.
should it be the 9 bolt 3.27 gears with posi?
and should it have an aluminum driveshaft?
Old Sep 22, 2008 | 02:23 PM
Engine: 2002 Ls1
Transmission: t-56
Re: question about 3rd gen rear ends???
anyone know what they measure from wheel to wheel?
Old Sep 22, 2008 | 02:38 PM
Stephen's Avatar
Car: 87 GTA
GTAs are generally 3.27 gears...All are posi, all are disc.
The aluminum driveshafts were a separate option & not specific to the rear end.
As for the width....I'm not real sure. The only thing I know is, the 4th gen rear are 1.75" wider per side, but I also hear the LS1 car rears are only .75" wider than the LT1 rears, but nobody has confirmed that.
TGO thread
Old Sep 22, 2008 | 07:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I think axle flange to axle flange is around 63". Maybe 65". If you use the search feature, it will probably show up. It's been asked before.
The 88 GTA with the 5.7L will probably have a 3.27 9 bolt diff with posi. I doubt it will have an aluminum driveshaft from the factory.
Why do you need to know the width? The only other diff that will be a direct fit is from another third gen or a fourth gen but the fourth gen diff is wider by 2" on each side. You can't put some other junkyard diff under a third gen without doing a lot of suspension modifications.
Old Sep 22, 2008 | 08:16 PM
Engine: 2002 Ls1
Transmission: t-56
cause im selling it and the buyer has a custom street rod and and wanted to know, i searched and couldnt find it, maybe im typing the wrong thing in....
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
