Does the Transgo kit allow 3-4 WOT shifts?
Old Jan 11, 2001 | 06:48 PM
Josh 91RS's Avatar
Ive seen this said a few times...when talking about the b&m vs. the gm upshift valve kit. People mentioned that the Transgo can do this. I do want WOT 3-4 shifts. I just ordered a Transgo kit so im wondering if I even have to get the GM upshift kit now.
Thanks Guys
Old Jan 11, 2001 | 10:10 PM
CamaroMike's Avatar
Not unless you buy their 50 dollar valve that is identical to the GM one. You will see what I mean in the TransGo instructions. BTW TransGo does not give instructions on how to install their 4th gear WOT shift valve.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Jan 12, 2001 | 09:01 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Are you kidding CamaroMike? I have this kit right in front of me. When the kit arrived, I opened it up to see what came with it (and watched the video also ). And yes, it does come with the upshift valve (and a servo assy similar to the 'vette one) and it does allow upshift to 4th at WOT (same as the GM unit). Plus the video and instructions show you how to put it in.
Do not buy anymore parts, the TransGo comes with everything (except a higher stall converter ). Now I might have to sell my 'vette servo because I don't need it.
George P. Lara
1984 "L69" A4
1994 LT1 M6
Member:
SCCA, SCFB, SC3GFB
Old Jan 12, 2001 | 10:57 PM
CamaroMike's Avatar
Look in the goodies section there is a 4th gear WOT shift valve that is extra! The WOT valve is only for pre 87 transmissions. So you may have what you need already.
[This message has been edited by CamaroMike (edited January 13, 2001).]
Old Jan 13, 2001 | 02:24 AM
Josh 91RS's Avatar
Damn, thats hella ****ty. I have a 91. Well at least it comes with the servo...and thanks for telling me that cause i was about to go get one. Damnit, I really wanted that WOT upshift valve. Another part to order, more money...it just never ends
Old Jan 13, 2001 | 10:07 AM
CamaroMike's Avatar
NO NO NO! The pre 87 trannys require the WOT valve. The later models do not require the WOT shift valve. 87 and up will do a WOT shift with the basic TransGo kit. Get it?
Old Jan 13, 2001 | 01:35 PM
Josh 91RS's Avatar
OH OK I GET IT!!! HELL YA, THANKS FOR MAKING THAT CLEAR!!!
Old Jan 13, 2001 | 06:16 PM
Dan87IROC-Z's Avatar
You can just purchase the valve from GM, you don't need the shift kit to have an upshift at WOT from 3-4. I just thought I'd throw that in!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: LT4 Hot Cam, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Fully Ported TPI Plenum and Base, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Old Jan 13, 2001 | 07:45 PM
Josh 91RS's Avatar
Thanks dan, i know you can just buy the valve. But i already purchased the shift kit because i wanted the shift kit...i just didnt want to have to buy the valve TOO...but now i know i dont have to
devilschariot
Feb 25, 2016 03:08 AM
86Firebird86
Dec 26, 2015 07:21 AM
FormulasOnly
Sep 6, 2015 10:42 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
