4 out of 5 sucks
Old Jan 14, 2001 | 07:22 PM
ROBBIE R's Avatar
4 out of 5 sucks
I own a 88 camaro 2.8 5 speed. comming home from work i had to down shift to fourth gear when i went back to fifth gear there was nothing trere. like neutral.no grinding no noise what so ever. i have reverse through forth.i plan on tearing it down next week and i would like to know what i should look for??? i only have the weekend to fix it. any help would be greatly appreciated.
Old Jan 14, 2001 | 07:51 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
There is a snap ring that holds the drive gear on the main shaft, it sometimes slips off. You'll see it when you pull off the tail housing. Be sure to get a new snap ring when you put it back together and don't stretch it to much when reinstalling it. When you put the gear back on you just need to tap in on with a brass punch or similar device.
Chronologically challenged. But still kicking!
92 CAMARO RS
305 TBI 5/spd (now TPI)
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+
Pac J
May 17, 2020 10:44 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
tyeo098
Nov 30, 2015 06:27 PM
wanext
Oct 6, 2015 12:18 AM
3.8TransAM
Oct 1, 2015 07:47 PM
