question on shift points on 700r4's
Old Sep 24, 2008 | 05:48 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
two questions,my car is a 89 with a 350 tpi,the trans when it gets warm is a little soft in my opinion. it dosent grab the gears when it shifts like when it is cool.i have another 700 from a 91 rs that had a 305 tbi motor and the trans shifts nice and hard.will it have the same stall and shift points as my trans.
Old Sep 25, 2008 | 04:30 PM
8992guy's Avatar
Re: question on shift points on 700r4's
Are these trans. and stalls all stock?Your shift point and firmness is determind by a few things but yes everything should be pretty much the same. The TV cable is the most important, make sure you set it before driving. I also belive on the 91 trans the speedos electronically controlled.
Old Sep 25, 2008 | 06:15 PM
regal301's Avatar
Car: 1988 iroc-z
yes they are both stock.my car has an electronic speedo also, but i think the sensors are different.i have the cable set correctly on my trans,it wasent when i got the car,and i fixed it when i replaced the motor.i also had the pan off my trans and put a new filter and gasket and refilled it with b&m trick shift and im still not happy with it.no bad stuff in the pan.
jklein337
Sep 19, 2018 06:23 PM
redmaroz
Aug 16, 2015 11:40 PM
TreDeClaw
Aug 14, 2015 06:58 PM
gwade12
Aug 8, 2015 08:17 AM
