Speedo cable and aftermarket gauges... need advice.
Old Jan 19, 2001 | 04:03 PM
Biochem's Avatar
Car: 2002 SOM z28
I am redoing my in-dash gauges with Autometer ones. My question is about the speedo cable. Stock, it pushes into the rear of the gauge and is held on by a clip. Autometer, it screws into the rear of the gauge.
There is a company in CA that sells cables. They quoted me a price of $50 or so for a new cable, but I am thinking they are thinking that I need one that goes all the way from the gauge to the tranny. But when I look at it, I think I really only need about a 2' piece that will run from the gauge, through the firewall, and screws onto an extension that currently runs to the tranny.
Is this stock? If so (and I assume it is), what is the length of the piece that runs through the firewall? And is it as simple as that, and/or would it make sense to just buy the whole new line from gauge to tranny? I really don't want to have to go under the car in the winter to hook it to the tranny, but that o-ring does leak anyways and needs replacing (maybe the speedo gear too).
What do you all think?
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Jan 20, 2001 | 09:09 AM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
All I can offer is to tell you that the last time I replaced my speedo cable I discovered that certain years had a two piece cable, and others had a single piece cable. My car came stock with a two piece cable with the additional connector in the engine compartment, but when I went to the dealership for a replacement they first offered me a single piece unit. After talking with the parts counter guy for a while he managed to find a two-piece cable for me.
In summary, I have no idea which length this CA company may be offering you, but there definitely are two lengths available from the dealerships.
89 IROC with lots o' stuff
Old Jan 20, 2001 | 09:19 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If your car had cruise control, there will be a cable from the transmission to the cruise unit, and another from there to the speedo. Otherwise you will have a single cable from the transmission to the dash.
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 385 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
Because you can always sleep in your car, but you can't drive your house.
[This message has been edited by Apeiron (edited January 20, 2001).]
Veaceonee
Sep 29, 2016 08:15 PM
topteam54
Oct 6, 2015 12:21 AM
customblackbird
Oct 1, 2015 04:30 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
TrevinE
Sep 14, 2015 03:20 PM
