700r4 tv question
Old Sep 30, 2008 | 03:48 PM
adamsbomb's Avatar
700r4 tv question
I am looking at getting a 350 and 700r4 combo (95k ish miles for 300) It is fI from a 90. My question is, I am going to be converting it over to a carb setup (it is going in an 86 iroc that is fully gutted, including all harnesses and wiring) that will just be used for friday night drags. Do you need a tv cable on it for the tranny to work correctly in this situation. Would I be better to just get a crate motor a friend has with a spun bearing and do a rebuild and pick up a th 350 or powerglide?
I thought about just getting a manual valve body, would that work without the tv although that might b a bit down the road.
I got the car for free, so it is just gonna be a cheap weekend thing.
Old Sep 30, 2008 | 07:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700r4 tv question
You still need a TV cable. The manual valve body may not, depending on which one you have.
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
