TCI Speedo Chart Down: Need gear for 3.27 change
Old Oct 2, 2008 | 04:05 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I spent the last couple hours+ searching our site for a direct answer. I switched my 9-bolt 2.77 highway gears to the 3.27 set/700r4. I have an 88' IROC with the speedo cable and just want to know what color gear(s) exactly I need to change. I found lots of 'how-to's' but I must be thick brained.
The TCIAUTO.com calculator site is down/don't know if it's a permanent thing?
Can you help a mentally retarded member please?
Nitro-Nicky
Old Oct 2, 2008 | 04:38 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Re: TCI Speedo Chart Down: Need gear for 3.27 change
You need a lt blue 45 tooth gear.
Old Oct 2, 2008 | 08:46 PM
Nasty-Z's Avatar
Car: 1980 Z-28 /1992 S-10
Engine: 496 /421 Stroker
Transmission: 700R4 / Tremec
Axle/Gears: 4.88 / 4.30
It's back up right now
With a 17 tooth drive gear and a 25" tall tire the lt blue gear mentioned should work O.K.
http://tciauto.com/Products/Componen...eter_gears.asp
TOM
Old Oct 2, 2008 | 09:37 PM
neagan's Avatar
Thanks for pitching an answer in guys; I'm just ready to pull the driveshaft for a balance and a new set of U-joints and I was tearing my hair out looking for an answer. Interestingly, the shop that did the Stage III trany build just didn't seem to know what speedo gear was correct. That's when I knew I was in deep trouble....... Ouch! Nitro-Nicky
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
beachrodder
Aug 7, 2015 04:27 PM
