Vss and shift lite
Old Jan 25, 2001 | 09:57 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
Vss and shift lite
i get a code 23 for the vss and the speedo doesn't work and at the same time this happened the shift lite went out and i know it is not the bulb. so if i fix the vss will the shift lite work. also where is the vss once i got it looked at and they said i needed a gear i bought the gear then they said it was a gear in the tranny that was missing. if this makes sense to anyone reply.
thanx
350 vette engine
aluminum heads
235/60R15 BFgoodriches
3"flowmaster exaust
20% tint
Old Jan 25, 2001 | 10:13 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I thought that I had the gear in the tranny missing too, but I lucked out. My cable was broken. I would get under your ride, and check it out. What does the gear that you bought look like? I don't really trust any shops, so I always do things myself.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Jan 25, 2001 | 12:05 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
i bought the car like that and the kid said he had a new cable put in. the gear was orange and small they said it was suppose to conncet to the gear in the tranny. then they said the gear was lose in the tranny cause it is suppose to mesh with the orange gear i had. and also the orange gear i replaced it because the one that was there before was worn bad.
350 vette engine
aluminum heads
3"flowmaster exaust
20% tint
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
racereese
Oct 3, 2015 03:46 PM
