gear swap questions
Old Jan 24, 2001 | 11:56 AM
pimpintheRS's Avatar
gear swap questions
i have a 91 RS and i was wondering what series carrier i have i am going to buy some 3.42's from a 4th gen and was wondering if it'll work with the posi from slp or if i need more(besides the install kit).. i kn0w its a dumb question but i had to ask..
thanks
Shawn
Old Jan 24, 2001 | 12:51 PM
Dana92RS's Avatar
If you have a plain-jane RS (and not a B4C) than you should have a 2.73 rear if it is an automatic, and a 3.08 rear if it is a 5-spd. Both the 2.73 and 3.08 rears use 2-series carriers. If the 3.42 gears you are buying are from a 4th gen, they should be 3-series gears. The take-off posi unit from SLP is a 3-series carrier so it will work with the 3.42 gears. Make sure when you buy the gears and posi that they are both 3-series, as some manufacturers make 3.42 gears that will work with a 2-series carrier.
Old Jan 24, 2001 | 03:23 PM
i'll have to check with him to make sure it is a 3 series carrier before i go and buy my posi... thanks...
Shawn
Old Jan 24, 2001 | 03:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
the posi IS the carrier. So if you buy the SLP unit, your friends 3.42s will bolt right in.
ICON Motorsports
Old Jan 24, 2001 | 03:52 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Didn't 4th gens use a 8.5" ring and the 3rds used 7.5 (Except 9 bolts that used 7.75") rendering the 4th gen gears impossible to install in a '91 camaro?
Old Jan 24, 2001 | 04:50 PM
ede's Avatar
ede
joel, no
ICON Motorsports
1st & 3rd
Old Jan 24, 2001 | 06:03 PM
so i'll have to take the slp posi and the gears to the shop to get done no problem but does anyone know the around and about labor charges?i am looking at 140 for the gears and slp posi right now how much for labor?
Old Jan 25, 2001 | 12:48 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Depends on the shop. Call around and ask. Dont forget you'll need to change the speedo gears in your trans for the new ratio. Search this board or check the FAQ for which ones you need.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
InfinityShade
Aug 22, 2015 08:00 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
mizz0313
Aug 12, 2015 06:45 AM
