th700r4 help
Old Jan 25, 2001 | 02:08 PM
88rscaamaro's Avatar
th700r4 help
i need to know what year of a camaro tranny i need i have a 88 rs with a 2.8 in it now but iam putting a 406 in it and it will be carbed and in the 88 the converter lock is controlled by the ecm and i need to know what year i need and if there is anything i need to do to the crossmember or anything else before i get started any help will do thanks
Old Jan 25, 2001 | 03:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Look for a '87-later TH700R4. Astrovans w/4.3l V6 use basically the same transmission. You won't have to modify your transmission crossmember, but mounting the V8 on the front crossmember is a different story.
Unless you are using an ECM to control the 406, you'll need to get a lockup switch system (or hook up a manual switch you control). Summit & Jegs have them.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, TBD headers & hi-flow cat, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Cleotiz
Jan 6, 2018 08:56 PM
camaronils
Sep 20, 2015 02:57 PM
LilJayV10
Dec 18, 2001 06:20 AM
Ward
Nov 26, 2001 08:02 AM
Ward
Nov 26, 2001 07:49 AM
