Rear end out..how to disconnect E-brake cables
Old Oct 4, 2008 | 10:19 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Hey i have everything else out and the rear end lying on the floor under the car but i cant seem to figure out the easiest way of disconnecting the E-brake cables. Anyone have any suggestions?
Old Oct 4, 2008 | 01:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Rear end out..how to disconnect E-brake cables
drums or discs
Old Oct 4, 2008 | 01:41 PM
subroc's Avatar
Engine: 355 TPI
Sorry. Forgot that might help. Drum brakes. New one going in is Disc.
Old Oct 5, 2008 | 11:53 AM
subroc's Avatar
Engine: 355 TPI
Bump...anyone?
Old Oct 8, 2008 | 03:53 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I'm in the same situation... I have a 10-bolt drum that is being swapped to the 9-bolt disk in my sig. Can I reuse the parking brake cables?
Old Oct 8, 2008 | 08:07 PM
subroc's Avatar
Engine: 355 TPI
From what i have heard they are completely different. I haven't gotten to that point yet. I still gotta crawl under it and figure out how to unhook the ebrake cables from the car. That is literally the last thing to getting the rear out.
Old Oct 8, 2008 | 08:44 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
what part are you having trouble with, disconnecting from the brakes themselves or from the body of the car?
Old Oct 8, 2008 | 08:51 PM
subroc's Avatar
Engine: 355 TPI
Body of the car. It was late when i was working on it and it just looked like it was squeezed into some bracket and that i had to unbend the bracket to get the cable out.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
