Will a T5 out of an 88 305 T/A hold up to an a stock L98?
Old Jan 22, 2001 | 11:33 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Just as the above question states, will it hold up? How hard would it be to switch? I do powershift. Would that kill it? Would it help me in the quarter? Also, how would it affect the value of my car? Thanks guys
1989 GTA, L98/auto, t-tops, Black w/ grey int.
Ran a 14.85 @ 93.4 mph w/ 305 exhaust (2 little crossflow mufflers), descreened MAF, TB coolant bypass, and casting wall ground down behind throttle plates.
Old Jan 22, 2001 | 11:35 PM
84L69TA's Avatar
Car: 4 Mopars total
One more thing, would i have to change the computer? God I hope not
Old Jan 23, 2001 | 11:28 PM
84L69TA's Avatar
Car: 4 Mopars total
nobody knows at all?!
Old Jan 24, 2001 | 02:08 PM
RacinLT1's Avatar
if you are gonna drop in a L98,the T5 might or might not last. Powershifting will kill it a LOT quicker.My 305 has hurt at least 3 T5's(according to the last owner),and the WC that is in it now isnt doing good. I dont powershift it often,and NEVER do when im spraying. Next up will be a TKO. the stock T5 is rated at like 300ft-lbs,and the L98 makes more than that.
Dirk
1991 TA WS6 305/5 spd
Nitrous,hooker shorties,flowmaster 3" cat back,3.73's and a 160 shot of nitrous
DragStars 15x3.5 et fronts,15x10 rears with 275-50/15 BFG DR
1997 TA LT1
Draglites,15x3.5 sportsman pros
16x9 255-50/16 Comp TA's or Drag radials
Moroso CAI,no sway bar,dynomax non catback
Old Jan 24, 2001 | 03:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The factory didn't seem to think so...
I have a T-5 behind a 400, I have torn up quite a few. I've been real gentle to this one so it has lasted probably 25,000 miles so far, which might be a record.
It depends on how you drive it. If you drive it like me you could explode it the first time you back out of your driveway. On the other hand, if you're careful to avoid shock-loading it (that seems to be what torches them the fastest) it might hang in there for a while.
ICON Motorsports
Old Jan 28, 2001 | 12:27 AM
84L69TA's Avatar
Car: 4 Mopars total
well, thats what i figured. but does anybody else have any opinions or experiences with them behind stock 350's? Just to correct RACINLT1, i already have an L98 in my car...factory
Old Jan 28, 2001 | 12:48 PM
Killer-Z's Avatar
well thats put it this way my 305 is stone stock, runs mid 14's, and has ate the second gear. Another thought is that if gm thought the t-5 could hold-up to the punishment of the 350 don't you think they would've put it in from the factory. I agree with Dirk in that the TKO is the way to go. I'm going strait for it and using my t-5 as a boat anchor.
Old Jan 28, 2001 | 07:17 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
my T-5 had about 130000 miles on it when i changed from my LG4 to the 300hp 350 last spring. I didn't rebuild it, thinking i'd save my money and when it died, i'd swap a t-56 in. Well the engine has been in there for almost a year now, and the tranny is still going strong. I grind third gear a lot more than i'd like, but the new shifter should take car of that. If you ask me, the T-5 can handle the load of a stock L98 w/o many problems, but if your gonna spend the money to do a tranny swap , why not just go for the t-56? in the end it would probably end up costing you just about the same as a t-5 swap, and they can definately handle the extra power, just my .02...
86 Z28 red,
originally LG4,
new 350,
non comp Qjet,
T-5 five speed with new clutch,
stock 3.23 gears,
K&N Air Filter (best 35 bucks i ever spent!)
Edelbrock Performer intake,
crane 272H cam,
Accel 8mm wires,
Edelbrock performer cat- back,
Homemade cold/forced air intake.
KYB GR-2 struts and shocks.
Grant GT leather wrap steering wheel.
Sony X-plod stereo.
Optima 6x9's
Future mods:
NOS, Edelbrock TES headers, hi flo cat., 4th gen interior, 6 point roll cage, 3.42 gears
hurst billet/plus shifter, Edelbrock STB, IROC Rims
view my car
[This message has been edited by zupmanZ28 (edited January 28, 2001).]
Grant2k
Jul 10, 2018 04:01 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
matthew911
Aug 12, 2015 09:38 AM
marcusaw
Aug 10, 2015 08:13 AM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
