4th gen rear Question
Old Oct 7, 2008 | 12:53 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
I am looking into doing the 4th gen rear swap on my camaro but she is a 90 RS and I have disc in the front but drums on the back. The 4th gen should have disc so will it hook up or will I have to get something or what?
Old Oct 7, 2008 | 10:03 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Re: 4th gen rear Question
ttt
Old Oct 7, 2008 | 10:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Although it's a direct bolt in, there is no strength difference between your 90 diff and a fourth gen. The fourth gen diff is about 2" wider on each side so you'll either need to use fourth gen rims or buy new ones for the proper backspace so they won't stick out of the fenders.
If all you're after is the disk brakes, just put them on your 90 diff.
Old Oct 9, 2008 | 08:28 AM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
OK so is there a kit I can grab to add disc breaks to the back wheels or what do i have to buy? Also I really don't mind the wheels sticking out I think it gives it a beastly look but you said my thirdgen rims will not fit on them?
Old Oct 10, 2008 | 06:31 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
The wheels will fit, but they will look funny because they will stick out. I have an 91 RS and I swapped in a 4th gen posi/disk rear. Just search (4th gen rear, drum to disk swap), I got all my info on here, and this has been covered multiple times. Feel free to hit me up on AOL IM or a PM.
If you want to keep you 3rd gen wheels, just get a 3rd gen rear with disks and swap that in.
Old Oct 10, 2008 | 07:22 PM
Camaro5690's Avatar
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
I did a 4th gen rear swap, and Im running 16 inch irocs, I kinda like the look, it only sticks out of the fender about 1/8-1/4 inch on each side.
Old Oct 10, 2008 | 08:38 PM
krisb410's Avatar
As I said, it will look funny. Now if your tire is sticking out because you have really wide tires that actually fill to the inside of the wheel well, (not the inner edge of the tire only halfway inside the well), that's cool. But when lookfrom behind your car and you only have 245-275 tires, they just look way to pushed out.
But remember everybody, this is just my opinion. But it's food for thought.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
