Rear transplant
Old Jan 27, 2001 | 07:30 PM
nc-iroc's Avatar
Car: 1989 Iroc-z
Engine: 1998 L31 350
Transmission: 700 R4
Rear transplant
I have an '89 iroc with the BW 2.77 rear end with disc brakes. I have located a wrecked 89 RS 305 for sale and I need to know can I put that rear in my car. I believe it is a 10 bolt, and it probably has a better gear in it. My question is there anything that I should worry about (ie disk brakes etc). Thanks.
1989 IROC-Z Original 350 was swapped for a 305! Why, I'll never know.
Old Jan 27, 2001 | 08:11 PM
Birmass's Avatar
As for the rear swap, it's prety easy and is a direct bolt on. I'm not sure about making the brakes work though.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
Old Jan 27, 2001 | 09:27 PM
ede's Avatar
ede
you can swap the rears with no problems. swap the porpotioning valve out of the donner car while your at it.
ICON Motorsports
1st & 3rd
Old Jan 27, 2001 | 09:33 PM
327 firebird's Avatar
Well if the new rear is disc, since you said you have a disc rear it will bolt right in no probs. If its a drum then make sure you get the e-brake cables and you will need a prop valve that is for drums. Also the hard brake line for that rear(its different than the disc) The master cylinder you have will work. A disc M/C (J50)will work for drum and disc but a Drum M/C prior to 88 (J65)will work only for drums. Also you might want to invest in a new rubber brake line while ou have the brake lines disconnected.
Old Jan 29, 2001 | 06:54 AM
nc-iroc's Avatar
Car: 1989 Iroc-z
I'm more interested in keeping the brakes on my 9-bolt and putting them on this 10-bolt. Is it possible, will disc brakes bolt on to a 10 bolt drum rear.
Old Jan 29, 2001 | 09:17 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
It is not possible to put your disc setup on the drum rear, its something to do with the backing plate. Why are you doing the swap? because you want a higher (numericly) ratio? If you want to cheaply change the ratio, just do the disc to drum swap, just make sure to get all the parts that were mentioned above.
  • 89 Formula 305 WS6
    SFC's,
    LCA's,
    Air foil
    Flowmaster cat back
    Tranny Cooler
    A/F Ratio Meter, Trans Temp (not a mod but it sure spurs interest)
  • 90 Eagle Talon 2.0
    (winter beater)
Old Jan 29, 2001 | 09:23 AM
nc-iroc's Avatar
Car: 1989 Iroc-z
Thanks fellas. I really wanted a cheap 10 bolt with my disc brakes, it looks like I'll have to look elsewhere.
Old Jan 30, 2001 | 12:17 AM
Keith5's Avatar
Car: C1500
I saw an ad for a rear out of a GTA a few months ago, it was 10 bolt disc I think. It was $350.
1989 Pontiac Firebird Formula LO3 Auto
-180 degree stat
-Hooker Cat-Back
*****Possible summer '01 mods*****
Open Element, Auburn Posi, Keyless Entry, wonder Bar off the IROC, 4th gen seats, T/A tail lights
1985 Camaro IROC-Z LB9 Auto
http://www.geocities.com/krt80/
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
dag19
Aug 26, 2015 10:22 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
MY87LT
Aug 17, 2015 08:43 AM
