How can I tell if a junkyard tranny is good?
Old Feb 2, 2001 | 08:06 PM
Tab92bird's Avatar
I'm gonna open her up and look at the diff and take out the axles to check for wear, but other than that I'm not sure what to look for. Does anyone have any experience in this area?
Thanks,
Brandon
White '92 Firebird w/ 305 TBI. Open element w/ non drop base, increased fuel pressure, TBI spacer, Hedman Hedders & y-pipe, no cat, cat-back exhaust
Old Feb 2, 2001 | 08:22 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I think you are confused. The "tranny" and "diff" are two different things. If you are going to "pull the axles out and check for wear" then you are indeed looking at the differential. You will want to check the very large gear (ring gear) for chips, or unusual wear. You won't be able to see the small gear (pinion) without removing the carrier. The most frequent failure I see in differentials are the bearings, but this will also require dissasembly.
As for checking a tranny, you can take the pan off and get a "general" idea, but you won't know for sure untill you install and run it.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Thornburg
Aug 25, 2015 01:46 AM
TreDeClaw
Aug 14, 2015 06:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
drathaar907
Aug 6, 2015 04:20 PM
