hole for the shifter on a manual swap
Old Jan 30, 2001 | 04:57 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I need some pictures of the hole that the shifter goes through in the floor. I would rather see manual conversions, but I also would like to see some stock holes. Thanks for the help.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Jan 30, 2001 | 01:04 PM
Bort62's Avatar
Ive got some pictures of your Moms stock hole...
Sorry, Couldnt resist !
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jan 30, 2001 | 07:53 PM
Tom Keliher's Avatar
Here ya go:
FORMULA 350 TK
Southern California 3rd Generation F-Body OrganizationŠ
Old Jan 31, 2001 | 03:01 PM
stingerssx's Avatar
Thanks Tom. Did you measure straight across from the seat bolts? And do I really need to make the hole that large?
Old Jan 31, 2001 | 05:41 PM
I took measurements from a factory 3rd gen, T-5 equipped car. That hole is the exact size, and the exact location as factory. The lower boot will cover that hole with approx. an inch all around for the sheet metal screws to hold it down.
Old Jan 31, 2001 | 06:29 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Tom what size is the hole?? I am going to be doing this swap soon...What did you use to cut it?? It looks great! Thank You Kevin
Old Jan 31, 2001 | 10:33 PM
The factory GM cutout measured 5.5 x 7.0 inches. I made this cutout 6 x 7 inches.
I drilled a hole in each corner to fit a sabre saw blade and then used the jig saw to cut it out.
FORMULA 350 TK
Old Feb 1, 2001 | 03:41 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Hey thinks for your help.. Kevin
Old Feb 2, 2001 | 01:33 AM
IROCZteady's Avatar
Hey Tom, I have a question. I'm planning on making the cutout pretty soon, but I think that the original factory dimension is just too big. I purchased an aftermarket rubber shift boot with an approximate dimension of 4.5 x 6 inches. I was thinking of cutting the hole to this dimension, which allows for enough "transmission shift" movement. This will also give me the option to enlarge the hole if I later decide to put in a 6-speed - I've read that with the 6-speed, the hole requires enlarging 2 inches back. What do you think? Is this enough clearance?
Old Feb 2, 2001 | 08:25 PM
My Opinion:
Don't use a smaller aftermarket rubber boot. Get a genuine GM boot, and cut the hole the approximate correct size.
FORMULA 350 TK
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
NBrehm
Aug 25, 2015 11:49 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
