speedo gear ques... 91kevinz, pro built and others
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
i need to know if the part number for the driven gear for 3.73 ratio 7 r 400 are dicontinued. i believe it is the set with the 15 tooth drive 45 or 41 tooth driven. Either way i ordered the 2 and ended up with my 15 tooth and a 45 tooth grey/lt blue it looks like its for either a T-5 or a th350, and won't fit into the sleeve. All info helpful. I need this over with soon
'89 SHAGGY IROC
L98 7r4, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc.
so much to do , so little money
[This message has been edited by irocnroll89 (edited February 04, 2001).]
'89 SHAGGY IROC
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
Does the gear you just bought have a 1/4" boss on the inside that is keeping it from going all of the way down on the D shaft? If so, you can grind off the boss flush and use the gear.
I've had to do this before.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
KevinP92Z
i have a pic , but can't post it. the gear looks just like the ones i used to use on my th350 on my 81 z28. the 7r4 gears have metal shafts. This one is completely plastic. the end (looking down it) has a square port dor the speedo cable but there is no way this belongs with my car. i have numbers, though i don't know if they are for my 3.42 gear set that i have. the numbers are p/n 8640517 and p/n25522497. thnx for responding
For a 700R4 with 3.73 gears:
8642620 - 15T Gray Drive Gear
9780470 - 44T Dk Gray Driven Gear
These are still available. I ordered them about a month ago and are sitting on my desk waiting to be installed.
1989 IROC-Z 5.7L
1989 IROC-Z 5.7L
ambainb
Apr 25, 2016 09:21 PM
someone972
Aug 30, 2015 12:52 AM
Dialed_In
Aug 20, 2015 01:45 PM
