T56 alignment question?
Old Oct 13, 2008 | 10:44 PM
peepsrs's Avatar
Car: 91 Rs
Engine: 383 hydrolic roller carb
I put a T56 with the sphon crossmember in my 91 camaro today and the trans mount lines up in the side hole on the crossmember....there are three holes for the transmount bolt to go through and mine is not falling in the center hole. I am just wondering if this is normal or if I should be trying to get it in the center hole?
Old Oct 14, 2008 | 07:31 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: T56 alignment question?
Does your crossmember have the driveshaft loop with it? Mine does and if I didn't put the tranny in the middle slot, the driveshaft was too close to one side of the loop. If you don't have the loop, it shouldn't matter which slot you use, as long as there's no other clearance issues.
Old Oct 14, 2008 | 11:42 AM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
The crossmember probably needs to be moved. The holes where the cross member attaches to the car are elongated so just loosen the bolts and moved it around until the tranny mount lines up.
Old Oct 14, 2008 | 11:09 PM
peepsrs's Avatar
Car: 91 Rs
just to make sure...the mounts are all the same corect?...I have an energy suspension mount that I used on my 700r
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
383backinblack
Aug 15, 2015 06:36 PM
reiderz iroc
Aug 13, 2015 04:57 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
