T5 Shifting Problem
Old Oct 15, 2008 | 08:30 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
T5 Shifting Problem
I just converted my car from an auto to a T5. When the car isnt running the tranny will shift through the gears fine. However when its running it is either hard to get to shift into gear or it wont shift into a gear and when put in reverse it grinds. Im not sure if this could be the problem but when I put the pilot bushing in, it wouldn't go in all the way (stil had about 1/8 of an inch to go). What do you think it could be, the pilot bushing, or the clutch still needs to be bled more?
Old Oct 15, 2008 | 11:57 PM
89irocdrew's Avatar
Car: 89 355 Iroc Camaro
Engine: 355 TPI
Re: T5 Shifting Problem
try to bleed it more. When putting them in i have to always wiggle and shake the hell out of them to get it in. Be sure you haveit bolted up all the way. My buddy had a problem simmilar to this but his crossmember came loose and started to shift to the side some.
Old Oct 16, 2008 | 12:36 AM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
I'll bet the pilot bushing is installed backward. It'll go in either way, but when everything else is correct and it's having a shifting problem 99.9% of the time it'a a reversed pilot bushing. I know because i've done it. Put in a T5 tranny which I wrecked... Pulled it out to put in my new W/C T5 and found that the pilot bushing was in backwards. I have a strong left foot so I never thought anything of it, until I corrected it... Big difference.
Old Oct 16, 2008 | 11:01 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Can any harm be done by having that pilot bushing sitting out that little bit?
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
