4th rear help
Old Oct 16, 2008 | 08:04 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
4th rear help
I just installed a 4th gen ls1 rear into my 85 everything went perfect till my first test ride.
There was some noise comming from it and I found the pass axle bearing is whipped out along with some grooves in the axle.
It is an abs rear and i need a new axle. Do I junkyard hunt for 1 or buy moser axles for it? It looks like the mosers are 291 on jegs ouch!!! I only paid 350 for the rear and already have about 800 tied up into it.
Also do you think I should pull the whole rear out to flush it all out from the bearing failing?
Old Oct 16, 2008 | 08:05 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Re: 4th rear help
Contact Dave mc. Same exact thing happened to me and he helped me. Hes got tons of axles.
Old Oct 16, 2008 | 11:02 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: 4th rear help
Guess you should have checked before you put it in.
Lesson learned! Too bad you learned it the hard way.
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
